Step 5Putting the hub into the cut
If you are putting the board directly inside the can you need to push one end of the board through the middle of the slit at an angle and then pull it round and into place so the ports are all in the slit...
If it's sitting at an angle (as in your ports aren't flat on the can you need to put something into the can to push the board straight ( your options are either a big pin from the outside or a small bit of card or foam just whatever fits but the latter need the top taken off to work.
Are you done?
If you want a really cool look try cutting individual holes for the ports but it will take a lot of beer drinking to get right.
Add Comment
