HOW TO MAKE a FANCY BEER GLASS
2,371
84
14
Posted in CraftArt
Introduction: HOW TO MAKE a FANCY BEER GLASS
About: I'm a French Canadian from Shawinigan. I just want to start it with the proof that nobody is perfect! I’ve produced free humorous woodworking videos for more than one year now. However, this is not my full ...
A nice drink is much better in a nice glass...
This is why I turned this beer glass on the lathe!
Special thanks to Bill Livolsi at One Car Workshop for helping me write this article!
Step 1: Tools & Materials
  • wood lathe
  • drive center
  • scroll chuck or faceplate
  • roughing gouge
  • hollowing chisel
  • epoxy glue / hot glue
  • little glass bowl
  • supply of poutine (optional)
  • face shield
  • face shield
  • FACE SHIELD
Step 2: Preparing the Blank
Prepare a blank with dimensions 3" X 3" X 6". You must mark the center on both ends of your blank before mounting it on the lathe. Otherwise, the piece will wobble.
Step 3: Mounting the Piece on the Lathe
With a drive center installed, mount the blank on the woodturning lathe. Be sure your blank is well secured.
Step 4: Roughing Out the Piece
With a roughing gouge, make the square piece round. CAREFULLY ease the cutter towards the blank to reduce the chances of a catch. Don't just stick it in there!
Step 5: Making a Tenon
Make a tenon on one end of the blank. A tenon gives a scroll chuck something to grab and allows you to work on the other end without tailstock support. If you do not own a scroll chuck, start with an extra-long blank and use a faceplate instead. You can cut off the excess when you're finished.
Step 6: Trim the End
With a hollowing chisel, square off the end of your blank.
Step 7: Hollowing Out the End of the Piece
Using the hollowing chisel, make a bowl shape at the end of the blank. You want the shape to match the bottom of your glass as closely as possible, but an exact fit is not required (the glass will be secured with epoxy later). You can check the fit by stopping the lathe and inserting the glass, but do not take the piece out of the chuck!
Step 8: Applying Finish
At this point, you can apply finish to the inside of the bowl. I used polyurethane and then, after it dried, buffed it with beeswax.
Step 9: Start Shaping
Use your creativity to carve an original shape of your taste.
Step 10: Making the Captive Ring
Begin forming the shape of the captive ring. Start by thinning the stem of the goblet while leaving one area near the middle thicker. Forming the ring near the middle makes it easier to separate it later.
Step 11: Sanding the Ring
Before parting off the ring, we need to sand it. Once it has been parted off, we cannot work with it any more.
Step 12: Parting Off the Ring
With the chisel, make an undercut on both sides of the ring to part it off. This cut also defines the inside shape of the ring. To keep the ring even, work slowly, taking light cuts from alternate sides until you break through.
Step 13: Defining the Final Shape of the Cup
Now that you have your captive ring done, it's time to define the final shape of your cup. Again, this is a matter of personal taste. Get creative!
Step 14: More Sanding
Sand the piece, starting with a low-grit sandpaper and moving up to higher grits. In the video, I started with 180 grit and finished at 600 grit.
Step 15: Putting the Finish On
Apply finish to the rest of the cup. Once it dries, buff it with beeswax.
Step 16: Parting Off the Cup
With the parting tool, separate the cup from base section which is stuck in the chuck.If you don't have a parting tool, you can use a hacksaw or hand saw (stop the lathe before doing this!) or unmount the piece and use a bandsaw.
Step 17: Mixing Some Epoxy
Put glue on the top of your cup to welcome the glass vase. I used Epoxy glue, but hot glue might work as well.
Step 18: Gluing the Glass to the Base
You're almost there...
Step 19: Pour Your Beer
Or enjoy your favorite beverage! :)
Follow me, Share & Subscribe! :)
Website ► http://lepicbois.net/
YouTube ► https://www.youtube.com/lepicbois
Facebook ► https://www.youtube.com/lepicbois
Instagram ► https://www.youtube.com/lepicbois
Twitter ► https://www.youtube.com/lepicbois
Patreon ► https://www.youtube.com/lepicbois
    • Flowers Challenge
      Flowers Challenge
    • Slow Cooker Challenge
    • Spotless Contest
      Spotless Contest
    14 Comments
    This glass is so elegant and your videos are always superb. Stunning work Peekachu!
    This looks awesome! How much beer does the glass hold? I ask because I was thinking about it being used as a martini cup or wine, as for me, I'll stick to BEER!!!
    Being you are called the WOODPECKER, you should get in contact with marketing/sales of Woodpecker Ale and see if they would use your glass in their adverts. Maybe they could do some kind promotion or giveaway combining their beer and your cups/glasses. It' would be great recognition for you and who knows, maybe other beer companies see what you have and would want to be in on it as well.
    It can hold one bottle if you don't pour it llike me at the end of the video! LOL
    I've already have a friend who own a brewery. If I do this, he'll kill me! HAHAHA But it's a great idea though! :)
    wow what a craftsmanship! I love beer and I'm sure I would enjoy drinking it even more from this special glass! :) Nice one!
    Oh so fancy! This chalice would make even the most pedestrian of beers taste amazing :)
    HAHAHA Yes! :) Thanks! :)
