Beer Opener
Published
Introduction: Beer Opener
This tutorial wil show you how to make an automatic beer opener using arduino, 3D printing and laser cutting.
I didn't succeed in making the beeropener work properly because the servo motors I used are not strong enough.
possible solutions are:
  • using a stronger servo motor
  • using gears to increase the torque
  • using a spring to help the servo motors
Parts list:
  • 3D printed beer opener
  • 300mm x 200mm x 6mm plywood
  • 2x mg90 tower pro servo
  • arduino uno
  • 1k ohm resistor
  • pushbutton
Used tools:
  • 3D printer
  • lazer cutter
Used programs:
  • Autocad inventor (3D modeling)
  • Illustrator (laser cutting)
  • Arduino (code)
Files:
Step 1: 3D Model
I made a 3D model in autocad inventor.
Step 2: 3D Printing
The beer opener is 3D printed.
File:
3D print stl file: http://www.mediafire.com/download/b3m285ncw4bvd07/beeropener.stl
Step 3: Laser Cutting
The base is made from laser cut 6mm thick plywood.
file:
laser cut: http://www.mediafire.com/view/ax8b0b80i5w3a60/bee...
Step 4: Circuit
Step 5: Assembling
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    3 Comments
    Very brave to enter a contest with a contraption that does not work!
    You could apply what you've designed so far to make a manual opener that uses leverage, so it's still assistive.
    This is an interesting idea, but kind of a bummer it didn't end up working. Are you going to keep trying to make it work?
