Beer bottle fire lamp
Been drinking?
Bit dark?
Maybe it's time to tidy up, do the recycling, open the curtains, or instead you could make a few nice beer bottle lamps and say it's a new trend, if your place is a pit then the materials will be less then a few feet from you, in the rare case that you're tidy then you may need to walk to the kitchen...
Step 1House-hold materials!!!
house-hold materials!!!
These are the house hold materials you'll need to make the lamp:
  • beer bottle (a clear or green one is best)(i used a Chinese one)
  • cotton balls (no substitutes!)
  • a sheet foil (any will do)
To use it you need these:
  • liquid fuel (denatured alcohol and canola oil are good)
  • a source of ignition (matches, lighters, anything will do)
Stuff you Might need
  • funnel
  • an upside down bowl, or something else to snuff out the flame, for when you're done...
  • a fire extinguisher? i hope you won't need one...
89 comments
1-40 of 89next »
Jan 7, 2011. 5:38 AMbeehard44 says:
the first version looks like a molotov cocktail
Sep 17, 2008. 2:18 PMGoodhart says:
As fuels, I would think that Lamp oil, or kerosene might work well too (and they will not evaporate like alcohol does).
Jul 27, 2009. 2:11 AMsharlston says:
do you think olive oil will work?
Jul 27, 2009. 5:34 AMGoodhart says:
Hmmm, if it will wick properly, I am not sure though. It is used in certain types of lamps, but would be fairly expensive (at least in my area) as a fuel.
Jul 27, 2009. 1:44 PMsharlston says:
it has now been burning for 26 hours and its just nearly empty
Jul 27, 2009. 2:05 PMGoodhart says:
Well that's great. I knew that some lamps had used almond or olive oils in them but I wasn't sure how much they'd smoke if the wick wasn't trimmed properly.
Jul 27, 2009. 2:08 PMsharlston says:
glad you liked it i first tried the wick at 1cm and worked good for 5 hours and burned 5ml of oil then i tried at 7cm and it started smoking and loads of soot so i blew it out i will post pics if you want them?
Jul 27, 2009. 3:09 PMGoodhart says:
Sure, I am also sure I am not the only one that would like to see them :-) An old lamp, that used fired clay to wick, used in ancient times looks like this:
Jul 27, 2009. 6:14 PMsharlston says:
i mixed it with baby oil to thin it down a bit
Jul 27, 2009. 6:30 PMGoodhart says:
baby oil....I am assuming that is not oil made from babies LOL Anyway, yes mineral oils can be used also, but may impute things into the air one would not want to breath in.....I am not sure about that, but it seems probable.
Jul 27, 2009. 6:32 PMsharlston says:
i was thinking maybe we could collaborate a ible together on a oil lamp?
Jul 28, 2009. 2:57 PMGoodhart says:
I am not sure how much time I could devote to another project. I have two I am working on and about 12-16 irons in the fire as I get time....plus an up coming need for a few ELF detectors for the beta store front on MAKE I will be participating in.
Jul 27, 2009. 8:55 AMsharlston says:
ive just tried it and it works il post a pic later
Nov 14, 2008. 4:54 PMturnerfromdh says:
its good to use like vegetable oil because if you knock it over it doesnt catch on fire
Jul 27, 2009. 2:12 AMsharlston says:
does it smell bad when its burning?
Jun 25, 2009. 5:10 AMcornflaker says:
You might have a problem putting it out if it does though (its VERY hard to put out once you manage to set it on fire - just something to remember)
Jul 21, 2009. 6:20 PMcarpespasm says:
Smother it with baking soda, salt, dirt, or a fire extinguisher.
Feb 12, 2010. 12:27 PMsharlston says:
OR USE SOMETHING CALLED FINGERS
Nov 15, 2008. 9:15 AMGoodhart says:
well, if kerosene is not at the temp for combustion, it doesn't burn either, and needs to be wicked (I tried lighting some I had spilled on the macadam once...and couldn't. Although if you have enough of a flame and enough kerosene, it would....
But now days just about everything gives you cancer
Nov 17, 2008. 3:13 AMGoodhart says:
True, I am not so sure how well veggie oil will burn, it would be better to be able to adjust the wick so you get less smoking (burning any oil, even vegetable oil, can produce carcinogens); of course, this may just be true of any less volatile fuel.
Jul 27, 2009. 2:13 AMsharlston says:
i like alcohol as well
we could be alcohol buddies lol =)
Nov 17, 2008. 3:22 PMGoodhart says:
As long as the lamp gets used often OR the alcohol is put away in a sealed container when not in use for a period of time (to avoid evaporation) and one takes precaution not to tip the bottle over then it is probably the best fuel
Nov 17, 2008. 3:54 PMGoodhart says:
forgot one......if spilled when lit, spreads like....well....a burning liquid :-)
Nov 18, 2008. 9:46 AMGoodhart says:
quite a handy trait for use in your bedroom or den LOL
Nov 18, 2008. 3:05 PMGoodhart says:
and NOW where will you sleep ? LOL
Nov 18, 2008. 5:51 PMGoodhart says:
tee-pees are mobile....pick it up and run....
Nov 23, 2008. 11:12 AMDerin says:
are tee-hees mobile?
Nov 23, 2008. 9:03 PMGoodhart says:
tee-hee ?
Nov 23, 2008. 4:16 PMGoodhart says:
they can be moved, although they are not on wheels :-)
1-40 of 89next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:AnarchistAsian
my birthday is july 4th, it's pretty cool. so, i like making things, it's in my blood.(my dad is a physics prof. my grandpa was a computer engineer, and so on) i like making electronic devices and mec...
more »
