3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Begginer Fish tank
Begginer Fish tank
A simple step by step guide to setting up your first ten gallon tropical fish tank. If you enjoy it please digg it!
Step 1Information to know
Welcome to step one. I feel that before you go out and buy all the stuff, you should know a few things about keeping a fish tank.
1. If you want to have a fish tank, your going to have to put in time and commitment.
2. don't try to do something above your level.
3. you WILL have weekly chores.
4. fish are alive. treat them that way.
5. have lots of paper towels ready
29 comments
May 15, 2012. 5:02 PMharry88 says:
What would you do if you're sponge filter has the carbon inside of it
Jan 10, 2012. 10:32 PMjuicymoose says:
i dont know in gallons.. but will a 16-17 litre tank be alright?
Feb 12, 2010. 1:04 PMBECKBERRY says:
sweet
Sep 27, 2009. 1:58 AMAmyLuthien says:
Depends upon the water quality you have available how quickly you can add the fish. I'm lucky, I have well water that filters through about 300' of layered coal, sand and clay. It is absolutely pristine when I pump it out of the ground and into my house, so I literally can fill an aquarium with water and put the fish right in it without waiting. And yes, I've got everything from koi ponds to salt water aquariums, and I've been keeping fish for a good 30+ years now - all using this same water.
I will say, you should never ever add the water the fish came in to your aquarium. Buy a bottle of Cycle instead. The Cycle will add the bacteria you need, but not the chemicals etc. you will find in the water from the store.
Sep 4, 2009. 4:17 PMminipancho94 says:
just wondering what do you do if you use a fine substrate like live sand or something and what fine substrate would be best ora tropical freshwater tank
Aug 3, 2009. 10:18 PMsteblublu says:
Thanks for the instructable - the info was good. i'm building my own aquarium and needed to know a little more about maintenance issues - so you helped alot. The only criticism I would offer is that after reading your PDF, I would suggest to the author that he may want to find an "English spelling" instructable..... :)
Aug 2, 2009. 1:07 AMRunning Wolf says:
You can also do a 50% water swap out every other week, but make sure to check the water parameter, change sooner if the water is going bad. For your first tank you will most likely not want to go with a liquid test kit (about $35), the $10 strips should be good enough.
Jul 1, 2009. 2:19 PMlego man 655 says:
and it should not be by places that are affected by heat so don't put the tank near any windows or any places that are in the path of direct sunlight.
Jul 1, 2009. 2:16 PMlego man 655 says:
i disagree i started a 20 gallon tank and i waited for about 24 hours and put fish in and its been over 2 weeks and they are fine
Jun 9, 2009. 8:20 PMkashell4crab says:
Well said for the most part although I have two things that I would like to add: Decorations: chose decorations that are compatible with the type of fish that you will house. For instance I have Black Moors (bubble eye or telescope eye fish) these type of fish can injure themselves (eyes) on sharp reefs and or plastic rough or pointy plants. and number 2 is a safety feature place your electrical bar above the floor but below the socket on the wall as for the cord to form a "loop" in case of a water leak to prevent electrocution/fire. that's all great instructable.
Apr 21, 2009. 7:22 PMbassmonkey says:
dude, you wait two days to put any fish in, thats the most important thing
Mar 31, 2008. 12:24 PMfeeshy says:
It would, however, be avoiding animal cruelty if instructions were given for a fishless cycle. I also would avoid taking 'advice' from retailers- as is often the case, if it makes them money, they'll sell it, whether it's a good idea or not.
Apr 21, 2009. 7:18 PMbassmonkey says:
you have no idea how much i agree to that
Apr 21, 2009. 3:19 PMdudejetfighter says:
ya my local mom-and-pop pet store is the best for questions.
Aug 16, 2008. 2:21 PMMakerBreaker says:
the best information is if you take time and search on google. In this instructable you never mentioned the diseases the fish might have. and itseems you have no real plants in the tank. your tank is not that healthy.
Sep 14, 2008. 10:41 AMoi says:
The only responsible "fish" instructable I have seen so far although like said before you failed to mention anything about cycling the tank before adding fish, and nothing about quarantining the fish from the pet store before adding them in with your new fish.
Apr 15, 2008. 5:59 PMGuppy8 says:
you didn't cycle it...
Mar 31, 2008. 9:41 PMiairj84 says:
I think overall this is a pretty good recomendation... Although there's a few MAJOR things that stand out to me as I've been keeping fresh and saltwater fish for the better part of 10 years now... The first being when you're mentioning to add prime and stress zyme, both are very good products, but they don't make a tank safe for fish.. This is a process called "Cycling" and it can't really be done without adding a source of Ammonia. I.E. Pure ammonia... This is what fish put out when they poop and pee. The stress zyme doesn't break down this safely and it takes anywhere from 2-4 weeks before your tank is cycled. Once the filter has cycled you can start adding a FEW fish, not a lot but a few... This cycling process will no doubt save a lot of little fishies from ammonia poisoning and death. It makes no sense to check the water when nothing other than the water conditioners have been added, because of course the water is perfect as far as water quality goes.
Mar 30, 2008. 10:56 PMw00ty32 says:
well written, good Instructable But:
you kept spelling thermometer like thermomiter
sorry to tell you this, as you used the word like 10 times.
better catch it early than have more of the grammer nazis of this site hound ya.
Mar 31, 2008. 4:22 PMw00ty32 says:
eh, i think those things too.
Mar 30, 2008. 9:03 PMTheScientist says:
that was awesome. i'm going to be setting up a tank in the near-ish future, so this was a good read! well written and layed out too
Mar 30, 2008. 8:38 PMSergeant Crayon says:
Good job! I like how you specified to wait a month before adding more fish (I find this important). My favorite set up for a 10-12g tank usually contains a small school of neon tetras (5), a otocinclus cat (or two), a small snail (zebra turbo?) and maybe a freshwater clam. (They're great fun to watch.) Also, if space allots, a cherry or ghost shrimp. (These are hands down my favorite.) I have had great success with this setup; the cats clean the plants, the snails clean the glass, and the scavenger cleans up the gravel. Fairly low maintenance community. Although may be slightly crowded for a 10 gallon. Anyways, you've covered the basics superbly!
Mar 30, 2008. 8:27 PMLinuxH4x0r says:
Cool! now if only someone would do a salt water one.....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:Mr. M
