3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Beginner Cigar Box Guitar
This is more of an uninstructable than an instructable, but hopefully my mistakes will benefit other beginner makers.
I’m part of a small group of beginner makers in Atlanta, GA called AHWIG. For our most recent meeting, we decided to make cigar box guitars using Discontinuuity’s excellent instructable. However, since none of us knew what a coping saw was, much less how to operate a power tool, we were befuddled by the instructions. This instructable that assumes the reader knows NOTHING AT ALL about making stuff.
Many thanks to Discontinuuity for inspiring a new crop of makers.
Step 1Parts & Tools
Parts & Tools
Parts You'll Need:
  1. Cigar Box
  2. 3' length of 1"x2" poplar board
  3. Guitar tuning pegs (You only need 3, but they come in a set of 6.)
  4. Guitar strings (Get a pack from any music store. Some stores even sell individual ones. You only need 3 strings.)
  5. Bridge - part A: Something to anchor the strings at the top - anything you can drill 3 holes through. I used a small hinge which already had 3 holes, but a piece of scrap metal would also work. One of us used a tiny antique key with 3 holes in the head.
  6. Bridge - part B:  I used a small piece of trim. Discontinuuity used a bamboo chopstick.
  7. Something to make the nut. I used the same trim that I used on the bridge, but in retrospect, I should have used something with a thinner profile. Discontinuuity used a nail with the tip cut off.
  8. Random chunks of wood. An old 1 1/2" thick  deck rail that is angled on one end is perfect. (deck rail = skinny piece of wood that runs vertically.)
  9. Random hardware. The tuning pegs & hinge came with their own screws, but I needed a spare screw to attach the tailpiece.
  10. Wood glue
  11. Tiny hinges for your box if yours doesn't already have them. (heh, heh. I said 'box.')
Tools You'll Need:
*Note: You don't absolutely have to use power tools, but some of us had them, and we were all thoroughly over-excited about getting to use them.
  1. 1/4 sheet palm sander (You can sand by hand - but an electric sander sure saves time.) & 1/4 sheets of sandpaper in various grits
  2. Drill
  3. Dremel tool with sanding barrels and cutting wheels (Mine was the cheapest, cordless version. A couple of the others had fancier ones with up to 10 speed settings. This is probably the most optional of the tools. I mainly used it for sanding the f-holes.)
  4. Clamps (2 or 3)
  5. Chisel
  6. Pencil
  7. Utility Knife
  8.  Snips (You only need these if you're working with metal for your bridge piece.)
  9. Small keyhole saw
  10. Ruler
  11. Hand Saw
16 comments
Jul 6, 2011. 7:15 PMC_Maconroe says:
If I get 4 bass strings and a long enough neck would that be a cigar bass?
Apr 9, 2012. 6:48 AMlukev2 says:
im a bass player and yes, it will work........ if u really want to make it diy, use weedwacker strings because they are cheaper and are good if already have them......
Dec 30, 2010. 10:16 PMwoeandwonder says:
could i just cut the notch in the cigar box to accomidate for the lid? or do you have to cut down the neck?
Jun 1, 2011. 9:32 AMbbostick says:
I built one that did not include a notched neck, a few days ago, (my first one actually). It just a has deeper cut into the box so that the lid could close all of the way. It works more or less, but the problem with that is that you end up not being able to fret all the way up the neck; at a certain point the strings hit the edge of the lid. With the notch cut in, the neck should be completely flush with the lid.
Apr 30, 2011. 2:31 PMmhyden1 says:
Harry Potter in the background!
Mar 24, 2011. 3:59 PMonlyjus says:
Sweet! I built two so far and have collected a pile of cigar boxes for more!
Check them out here: http://onlyjus-cbg.blogspot.com/
Oct 11, 2010. 4:23 PMdirtyroger says:
nice build, are you using nylon strings??
I'm starting a blog on my first CBG here dirtyguitarguide.com
Jun 7, 2010. 7:48 AMtravisrichardson1980 says:
hey, well done, but i'd have to say you took some steps that would be difficult for a real beginer to follow, that may not be necessary. you built something that may work out really well for you, but i would hate to ask a complete novice to notch out a neck or to cut f-holes. seriously, this is a nice build! you should be proud of it!!!!! i'd love to see a video to see/hear how it sounds! feel free to check out my build method here, it may give you some ideas about simplification... http://www.instructables.com/id/cigar-box-guitar-in-one-hour-the-Uncle-Crow-way/ have a great day! [and if you're not already, come over to cigarboxnation.com and join the revolutioin!!! look for me there, my name is "crow"!!!!]
May 27, 2010. 12:15 PMdiscontinuuity says:
Cool guitar!  It looks like the strings sit pretty high off of the neck on yours; how does it play?
For the record, this is a coping saw (also called a jeweler's saw I think):
Glad I could inspire some makers!
May 27, 2010. 12:19 PMdiscontinuuity says:
Image uploading isn't working for me right now.  Here's the link if it doesn't work:
http://static.howstuffworks.com/gif/coping-saw-1.jpg
<img src="http://static.howstuffworks.com/gif/coping-saw-1.jpg">
Apr 29, 2010. 8:48 AMBIGA says:
ANYONE interested in these should go to CIGARBOXNATION.com and Handmademusicalclubhouse/ TED CROCKER  Peace / BIGA
Apr 25, 2010. 12:52 PMflio191 says:
You know, all you need to do to fix that straight pegged part is to add little metal catches that bring the string to where you need them before the top... like this:
imgur.com/J6klq.png
nevermind, just figured out how to upload directly to comments:
Apr 20, 2010. 1:46 PMmattthomas992003 says:
i like your idea for step5, makes sense i would have done that on my first build if i had saw your instr. first. but i like the neck to stick out of the back  of the box. anyway i liked your instructable it was good did you make it electric or did you make it for decor in your room?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:gerlindagrimes
