Step 3Chisel the neck
In case it's not 100% clear, your neck needs to fit all the way through your cigar box so that you can drill the bridge into the neck at the top of the box.
- Measure the depth of your cigar box lid and mark it on your guitar neck.
- Measure the length of your cigar box and mark it on your neck.
- Saw several cuts into the top of your neck, using the guides you've just drawn.
- Stick a chisel in between these cuts and apply pressure. The wood between the cuts should pop right out.
- Safety tip: Always chisel AWAY from yourself
- The chiseled-out surface will be lumpy and uneven, but this doesn't matter much because this part of the neck will be hidden inside your box.
- Still, if you're a perfectionist like me, you can use the palm sander to smooth out the rough surface.
- If your lid still doesn't close flush, sand a bit more around the edge that butts up against the notch you made earlier.
comments
Add Comment
Add Comment
