Step 8Tuning Pegs & Tragic Errors
- Create the headstock (ie: shape at the end of your neck that will hold the tuning pegs.) I decided to just leave the board as is, but your headstock could be any shape big enough to house the pegs. An example. And another. And one more.
- mark 3 places for the tuning pegs about 1 1/2 inches apart on the headstock
- Drill holes for the tuning pegs to pass through
- The pegs I bought came with little metal "sleeves" that fit down in the holes on the top side of the guitar.
- I made a mistake: The sleeves were wider than the tuning pegs, so I kept drilling larger and larger holes until the sleeves fit. This was probably a mistake. Maybe you are supposed to hammer in the sleeves like grommets?
- I made an even bigger mistake: I drilled my tuning pegs in a straight line. You should angle them a little. Otherwise, all 3 strings will bunch up at the middle of the nut, like mine did.
- Oh well, carry on.
- Pass the tuning pegs through the drill holes, then screw them into the underside of the neck.
Add Comment
