Introduction: Embroidery Tips and Decorating Plain White Dish Towels
This instructable will teach you a few tricks that I have learned from my mother on how to turn an ordinary white dish towel into a beautiful master piece.
I am a very active person. I can't sit still to watch a movie so I usually have some hand sewing near by so I feel like I am accomplishing something. I keep a sewing bag in my car as well. Doing this I am able to finish a lot of my projects very quickly. My mother taught me how to embroider as a child. It is my way of winding down from the day.
Step 1: Supplies
- Pre-washed white cotton fabric for the embroidery design; cut several inches larger than your design so it will extend the edges of the hoop. I used a 8inch circle.
- 1 Pre-washed printed fabric 2 inches wide and 24 inches long is what I used for the boarder on a towel or:
- 1 Pre-washed printed 8 inch square; folded in half for another towel.
- Matching thread
- Flour sack towels Please read bottom note
- Embroidery hoop
- Embroidery needle
- Sewing pins not shown*
- Scissors
- Seam ripper optional
- Embroidery thread
- Thimble optional
- Iron on embroidery pattern or iron on pencil for your own pattern
- Iron
- Ruler for square pattern
- For the circle pattern I used a clear round plate
- Chalk or marker
I have not been able to find fabric suitable to make my own dish towels so I purchased flour sack towels at Sam's but you can find them at a hobby store or Walmart. They are called flour sack towels because; in the early days dry goods were sold in cotton sacks and women would make clothing and towels from them. They have a loose weave and can be difficult to embroider; so instead I embroidered a cotton cloth first and then attached it to the corner of the towel. I was able to sew the design using smaller stitches which made it look better.
Step 2: Cutting the Cloth
I cut (circles and squares) from the cotton cloth large enough to fit properly in the hoop with extra cloth to hang over the sides.The size of transfer pattern used will determine the size of hoop you will need.I used a clear round plate to draw the circle. It worked very nicely.For the square I used a ruler to draw the lines and cut it out.
Step 3:
I suggest using a scrap piece of cloth that you will be stamping; to determine the heat setting.
Preheat a dry iron on cotton setting for heavy weight fabric or the wool setting for light weight fabric; make sure the iron setting will not harm the fabric.
Cut out the printed design removing any unwanted portion.
Place the design printed side down centered on the fabric.
Pin into place.
Place the iron on the transfer. Move iron slowly back and forth for 5 seconds.
Carefully lift up the edge of pattern to make sure the transfer design is clear.
If it is not clear repeat the above process.
A transfer pencil is used to trace a design onto paper to make your own iron on transfer.
Step 4: Place the Cloth Into the Hoop
Here is a link to another members page who did an incredible job explaining the different stitches! https://www.instructables.com/id/Embroidery-101/
Place the cloth into the hoop.
Slightly pull the excess fabric around the hoop so it is tight and secure.
Step 5: Embroidering the Design
Thread the needle using the recommended amount of strands. I used 2.
Do not knot the end.
Pull the thread through the hoop on the under side leaving a 2 inch tail.
Make one small stitch and pull the thread tight but be careful not to pull it all the way through. Leave a 2 inch tail.
Repeat a second time over the same stitch for securing the stitch. This method will have a more attractive stitch on the back side. I will show you the back side later.
Proceed stitching across until you need to re-thread your needle.
Be sure to secure the last stitch the same way you began; sewing the last stitch twice and trimming the thread leaving a two inch tail at the end.
Trim Thread.
Begin a new stitch overlapping the first stitch by sewing the first stitch twice as previously explained and continue sewing until you finish the design changing colors as you need to.
Leave a 2 inch tail before trimming the thread.
Step 6: The Running Stitch
Secure the beginning of the running stitch by sewing the first stitch twice leaving about a 2 inch tail.
You will need to do this each time you re-thread your needle with new thread and start again.
Continue sewing the design across as shown.
End by securing the last stitch.
Step 7: Finished Look
After the design has been embroidered; trim all the loose threads on the backside (close to the cloth) for a nice finished look.
The secret to making the design look pretty is closely following the design making very small even stitches and keeping your thread tight but not puckered. If you are cross stitching you simply make a stitch like an X. It takes practice and patience. I like using a short thin needle with a large eye to embroider. Another tip is not to try and make your thread reach across to make a stitch if it will make a larger stitch than you were sewing. This will make the wrong side look ugly and it could show through on the right side. It is best to secure the end and restart fresh with a beginning stitch. Doing it this way will reduce excess thread on the back of the cloth. I am sorry I did not take pictures of the back of the orange.
Step 8: Hemming the Edges
With right sides together (embroidered circle and the lining circle) pin the liner to the design.
Sew around the outside edge making a narrow 1/4 inch seam allowance.
Clip the outside circle edges with the scissors to the seam carefully. This allows the curve to lay flat.
Pull the lining of the fabric away from the design so you can carefully cut a slit allowing you to turn the fabric right side out as shown. Be careful not to cut the design side of the fabric.
Turn the fabric right side out and press.
Step 9: The Boarder
My mother would have sewn the border differently than I did here, but unfortunately I never saw her do this part.
I folded the square in half on an angle, pressed it and then turned under the raw edges to fit the corner and pinned it to the towel.
I turned down a 1/4 inch single hem on three sides of the white embroidered cloth leaving the bottom edge alone. It will get tucked under the border and sewn.
Then I pinned the embroidered square to the towel placing the bottom of the square under the border.
I stitched the border and square to the towel.
For the circle I pinned and stitched the border to the towel first; pinned the finished circle to the towel, and stitched both the border and the circle to the towel.
Step 10: Sunshiine's Final Thoughts
Flour sack towels are great to use to dry glassware and they are lint free. They are thin enough to get into small places to dry water spots. The downside is they wrinkle until they are washed a few times. Embroidered dish towels, pot holders, and pillowcases bring a comfy feel to the home. I hope you are inspired to embroider a set for yourself or for someone you love.
In closing I would like to thank our instructables company, sponsors, authors, readers, and members; for making this community a great success! Many hours and hard work has been put into making this place the best DIY on the Internet. Have a splendorous day!
Sunshiine
Sunshiine
Maker Moms Contest
