Beginners wiring projects: LED banks
Learn to wire up two sequences of three LEDs to a PC board, mount to a project box (Altiods tin), and control them with the use of a power and variable switch.
Please note that this is a beginner project, and that I am just learning to solder and wire myself.
The wiring here is fairly simple, but it takes some thinking to figure out, especially without an equally confusing diagram...
It's amazing how much I'm getting flamed for such a simple project. I fully acknowledge that it was possible for me to use a bigger battery with a resistor, however I did not have a resistor with the appropriate ohm value at the time for any of the batteries I had present. Not to mention this is a beginner project, and the button cells work fine, even with a sequence of three LEDs. To go even farther, the maximum voltage for the green LEDs is exactly 3v. A 1ohm resistor would be useless here. The maximum voltage for the yellow is slightly less than 3v, but enough that they've been left on for more than a couple days combined, and are doing just fine.
Step 1Materials
Materials
The materials required for this project are fairly basic, and most can be bought/obtained from RadioShack and your local hardware store.
Tools:
Needlenose Pliers
Soldering Iron
DREMEL (woo!)
Parts:
Wire - Any scrap will do, just make sure you have enough, it is extremely helpful if you have two colors
PC board - I got mine at RadioShack, they're cheap
Six LEDs - Three one color, and three another. All should be low enough voltage to be powered by 3-4 volts. (two 1.5-ish button cells)
Two switches - One 1-way and another 2-way
Solder
Two 1.5V Button cell batteries - Power
Electrical Tape
Multimeter - Optional, helps test connections
33 comments
Sep 13, 2007. 4:49 PMDELETED_Nicker987 says:
(removed by author or community request)
Sep 13, 2007. 3:40 PMPatrick Pending says:
Fireberto, you should have a current limiting resistor for each of your LED's.
A standard LED would (typically) have a maximum forward voltage of 2.5V applying a greater voltage will cause damage to them.
The two button cells are not really up to the job of powering 6 LEDs in parallel.
Cheers,
Pat. Pending
Sep 15, 2007. 6:10 AMPatrick Pending says:
The button cells you are using (alkaline or silver oxide) have a very low capacity (some are as low as 20mAh). The current drawn by a standard LED would typically be 10 - 20 mA. Three LEDs in parallel would require between 30 and 60 mA. You can see from the figures that the button cells wont last long!
Throwies are generally made with a single LED and a Lithium cell. These cells have much higher capacities than the ones you are using (e.g.,CR2032 > 200mAh).
Yes you can get away with not using a current limiting resistor in this case because the button cells are so underpowered for this application. The excess voltage is dropped across the internal resistance of the button cells.
Having a large tin and using tiny button cells just doesn't make sense. My advice would be to use two AA cells and series resistors of the appropriate size.
Cheers,
Pat. Pending
Feb 11, 2008. 6:43 PMHillBilly Homer says:
LSDiodes.com no longer sells LEDs. This part of the site remains only so that people can look up product specifications. You will not be able to purchase anything. very nice project and Instructable
Jan 2, 2010. 9:44 AMuotsey says:
 I have never done any type of wiring. I have a classroom project based on the nervous system. I would like to make something along the lines of the game "Operation" which tracks the path of the nervous system. Can anyone point me in the correct direction? Thank you!
Aug 22, 2009. 6:59 AMshostakovich says:
thanks....
Dec 1, 2008. 11:56 AMpyro man says:
wats the dremel for? can i just use 1 3-vlt battery?
Mar 28, 2009. 11:47 PMBlackHatCracker says:
Yes since each LED is only rated at 1.2v
Oct 30, 2007. 2:00 PMHandsome-Ryan says:
What does the resistor you soldered in line with the LED's do? Oh wait, you didn't use resistors. lol.
Mar 28, 2009. 11:45 PMBlackHatCracker says:
Well it is self explaining... It lowers the voltage going to said component. Ohms law... R=E/I to find the value of the resistor needed in any project that you are needing.
Feb 6, 2009. 8:39 PMcupnoodles2 says:
just for the next time u coul use the leads of the leds instead of using wire good ible btw
Sep 19, 2008. 2:51 PMmiqt says:
hey, thanks for the easy to follow instructable, i appreciate it...the pictures were pretty clear, i have 1 question though, is it possible to hook up 3 led's in the same way you did except without a pc board (just wires soldered onto the leds)? oh and if anyone else knows, i would appreciate an answer...from anyone.
Nov 26, 2008. 5:28 PMGjdj3 says:
Yeah, the pcb just makes it more organized. I normally don't use PCB myself.
Jul 7, 2008. 10:11 AMGjdj3 says:
That's really cool, but I think you used a bit too much PC board. It could have easily been done with less. But otherwise, great job! That looks like a good way to learn. 5/5 stars.
Mar 22, 2008. 10:38 PMimarzouka says:
Jan 20, 2008. 3:06 PMtimberman says:
i need help, want to make a sign with 50 maby 60 led's where can i go? i am a total beginner at this. bty your project was very helpful.
Oct 10, 2007. 9:45 PMDarkshot says:
cool man i luv the idea and totally wanna do this project but two q's 1) why the PC board? 2) why a 1 way switch then a 2 way switch? get back ASAP please
Oct 11, 2007. 9:06 PMDarkshot says:
mispelling is because im typing w/ 1 arm...others in a cast....long LONGG story
Oct 11, 2007. 9:05 PMDarkshot says:
ohhh i get the switches now you wanted to control one bank at a time right? but the PC board still sounds pointkless to me sorry if u think im geting on youur ass too much about the PC board :/
Oct 5, 2007. 10:44 PMtheatre_tech_guru says:
this Instructable is really good I liked it i am going to try it soon
Sep 13, 2007. 1:59 PMacaz93 says:
Excuse me , But I Think It's Multimeter and not Potentiometer
But Good Instructable , Easy To follow , Great Beginners Project
Sep 21, 2007. 7:14 PMacaz93 says:
hehe , no worry ;D
Sep 15, 2007. 8:37 PMrc jedi says:
I never get tired of led's. Their color is frequency specific. A pure color like one would see in neon lights. They make no heat and are energy efficient.They have long life, cheap and fast switching. aaaaaahhhh................................led's ':)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:Firebert010
I study engineering at Virginia Tech. Long time instructables fan.
