3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Beginning 5-String Banjo for Guitarists
There are several ways to tune a banjo, which are used for different styles of playing. For this instructional process, we will be using the most common: G tuning.
Unlike the guitar, the banjo has only 5 strings.  The string labeled 2 is the lowest string, followed by 3, 4, and then 5. The short string, labeled with a 1, is the highest. Here's how to tune a 5-string banjo in G:
#5: D - 1st string
#4: B - 2nd string
#3: G - 3rd string (one octave lower than the 5th string)
#2: D - 4th string (one octave lower and the 1st string)
#1: G - 5th string (the short string on top when holding the banjo)
If you are unable to tune the instrument by ear, I recommend using one of the many online banjo tuners available. They are extremely helpful when becoming familiar with what each note sounds like on the banjo, as opposed to the guitar. It is also important to familiarize yourself with the parts of the instrument, several of which will be referred to later in this tutorial.
Step 1Finger picks
Finger picks
While some play the banjo without them, most players use finger picks to enhance the sound of the instrument. There are two different kinds of pick used with the banjo: the fingerpick and the thumbpick.
The second image shows what the pics should look like on your strumming hand. As the image shows, the end of the fingerpick should not extend more than a few millimeters beyond the fingernail. It should fit snugly on the end of the finger, because a too-large fingerpick could get caught on a string and pulled off.  I only have one fingerpick currently, but most players use an additional pick on the index finger (positioned in the same way).
The thumbpick should fit around the thumb with the flat part under the pad of the thumb and the pointed edge facing outward. A properly-fitting thumbpick should not go any farther down on the thumb than the bottom of the thumbnail.
11 comments
Dec 3, 2011. 10:39 AMNateDay says:
Just to let you know, fingerpicks are actually designed to be worn the other way around. That way they don't get caught on the strings at all.
Feb 26, 2011. 3:55 PMthepelton says:
I recall a "Peanuts" strip in which Linus said: "When every child is born, he should be issued a banjo."
Mar 5, 2011. 12:21 AMmoosetooth says:
Thank you for reminding me of that little gem.
Mar 2, 2011. 1:22 PMGEESE GIRL says:
i have a friend that plays this instrument
Feb 25, 2011. 10:28 AMComputothought says:
Can not wait to see more. I used this so I could follow along. http://www.instructables.com/id/25-Drugstore-Student-Guitar-becomes-STEALTH-BAN/
Feb 25, 2011. 4:19 AMnauticalwheeler says:
The hardest part for me was training my ring and little finger to stay on the head. What I eventually ended up doing was taping those fingers together and they eventually "learned" to stay there. Also, even though it sounds a little gross, licking your fingers before putting on your picks helps them stay in place. Thanks for the instructable!
Feb 24, 2011. 10:44 PMPuzzledd says:
Thanks for this 'ible; I've been meaning to get out my banjo for some time, but it's easier to just keep playing guitar. I like the way you explain the transition to banjo, with nice, clear information- and an awesome video, too!
Looking forward to your next 'ible:)
Feb 24, 2011. 2:19 PMrandofo says:
Out of curiosity, did you learn to play the guitar before the banjo?
You should embed the video in step 5 so we can see it here.
Feb 24, 2011. 5:20 PMrandofo says:
Okay. It is embedded.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rachelwinter
