3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Beginning Arduino (Ports, Pins and Programming)
All right, so I am learning the art of Arduinoing and thought I'd take you along for the ride...
In this tutorial:
Pins -- the holes on your Arduino and how to use them
Ports--Collections of pins
Programming--Basic programming with the arduino
Step 1What you need:
What you need:
Arduino (mine's a duemilanove, but other versions should work as well)
LEDs -- at least one
Resistors --as many as you have LEDs (use this calculator to calculate what you need.  Voltage = 5)
Breadboard (optional)
Wire (optional)
Cable to connect Arduino to Computer
Software (not all that hard to install, not going over it in this tutorial, see this for how to install and other arduino usages get it here)
7 comments
May 20, 2011. 12:26 PMphevtron says:
so int ledPin = 13;
can be changed
for example become
int Col1 = 5
this tells the arduino that the pin 5 will be called from now on Col1 ?
thanks phevos
May 22, 2011. 9:58 AMphevtron says:
ok so to sum up
int col1=5 tells arduino that when i write col1 i mean 5 , and when i i type
digitalWrite(col1,HIGH) it will be like digitalWrite(5,HIGH) with 5 representing the pin but if the variable col1 is changed ...ahmmmm destruction?
May 22, 2011. 9:53 AMphevtron says:
hehe exactly, messing around with a home made 4x5 led matrix ;P
Dec 12, 2009. 5:57 AMletapjar says:
Nice instructable - one minor point:
In step 5 you have the following line:
The pins in the register are arranged from lower number = Least Significant Bit to Highest number - Most Significant Bit (so to get pins 0-3 to equal 0 and 4-7 to equal 1 it would be PORTX = B11110000)
The last part should say PORTD=B11110000 not PORTX
The code that follows is correct - but a newbie learning arduino from this example might be confused by that line.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:killersquirel11
