3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Belkin Tunecast II FM Transmitter Mod
Belkin is a popular manufacturer of cheap and cheerful computer accessories, having singlehandedly made the USB hub sexy! One of their more popular product hitching the iPod popularity ride, is the Tunecast II FM Transmitter.
It is only earlier this year (2007) that FM transmitters like these became legal in the UK, ignoring the fact that savvy netizens have already brought theirs from eBay.
This modification improves the transmission range and remove the 'feature' of auto-power down when no audio signal is present. It certainly sets you up as resident pirate radio DJ of your block and allows you to jam the loud radio listener on a bus or train!
Please note that this is a rehash of something that was done before 'instructable' came along. No more the delay now for the good stuff!
Product link:
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=263200
Step 1How to gut the TuneCast
Those ever efficient Taiwanese manufacturer manage to secure this piece of gadget with just a single screw, if you're handy with a screwdriver, that's the job done!
The first image shows the location of the screw (ignore the switch for the moment, that comes later), the second one shows where to a gentle pry will open it, note the plastic latch.
165 comments
1-40 of 165next »
May 14, 2012. 11:56 PMlherrera4 says:
Alternate Antenna Method: instead of adding a separate wire for the antenna, install the 3.5mm headphone jack and solder one end of a small piece of wire (you can use the blue wire that used to be the antenna) to the inductor bypass point and the other end to the ground on the headphone jack. The ground wire on the line-out cable used to hook up your mp3 player, will now act as an antenna; the longer the cable the better the signal. This works best when the cable is spread out
Dec 30, 2011. 11:23 AMFM Transmitter says:
Hey this is pretty cool! Does it broadcast as far as the WH FM Transmitter ? I heard it goes up to 150 feet.
Nov 1, 2010. 1:52 AMDarkcobra0 says:
The Corrugator, this is a great Instructible!
I used a different method to boost the output power, which will work not only for the Belkin Tunecast, but for ANY transmitter which uses a BH1415F, or even any other Rohm FM transmitter chip. Instead of trying to figure out what components were involved in the filter/attenuation network, I used a soldering iron and a toothpick to lift and disconnect BH1415F pin #11 (RF output) from the board. Then I soldered a quarter-wave wire antenna directly to the pin, which gives direct access to the maximum possible output power. Make sure the wire is secured so an accidental tug won't rip the pin off the IC; I used a generous application of super glue to attach the wire to the board near the connection. If a transmitter uses a different Rohm FM transmitter chip than the BH1415F, look up the datasheet to find out which pin is RF output.
The real gold in this Instructable is the auto power-off disable. I've been using this transmitter to listen to music from my computer anywhere in the house, and have been looking for a good way to disable the auto power-off. Up until now, I've been doing it by running a separate copy of Winamp that plays a subsonic or ultrasonic burst for two seconds, every 30 seconds in a loop. It worked, but on some radios you could hear a slight distortion when the burst played. This may still be a useful option for people who aren't comfortable soldering, or who have a different transmitter.
I just performed your auto power-off disable mod, and it works great! Though I did make one change. The pad you're getting power from appears to be active only once the transmitter is powered up, which still requires an initial audio input. So instead, I connected the transistor pin through a 1M resistor directly to the positive pin of the DC power jack. If you're looking at the board from the LCD side, with the power connector on the bottom, it's the second pin from the left between the large SMD capacitor and the LCD (verify it with a voltmeter if you're unsure you have the right one). The transmitter now turns on immediately when power is applied, and stays on indefinitely; regardless of audio input.
Finally, one more tip. Loop the power and audio input cables a few times through a ferrite toroid filters out hum and hiss. You can use one toroid, but it's easier to use two, one for each wire. The more loops, the tighter the windings, and the closer to the transmitter, the better it works. A clamp-on style ferrite should work almost as well, though I haven't tried. Obviously, don't loop your antenna through a ferrite, as this will attenuate the signal. If you haven't added your own separate wire antenna, skip the toroid for the audio cable, as it contains the antenna.
With these changes, I'm very happy with the performance of this transmitter; and its range and quality rival any consumer or kit transmitter I've tried for less than $100.
Nov 18, 2011. 8:48 AMjhettenhouser says:
I've tried this variant on two tunecast II's and the results are wonderful. Thanks both to you and the instructables parent.
Apr 18, 2008. 7:01 AMpigmeat says:
I have a Belkin copy, by a company called Sansai (see image) and it works great, but I'd like to modify it with guidance from your instructable post. My only problem so far is getting the damn thing open. Unlike the Belkin this thing has no screw and I had a hell of a time trying to pry it open (without success). Has anyone here managed to open one of these? If so, how did you go about it?
Nov 8, 2011. 2:35 PMuhclem says:
To open:
Slip a metal putty knife or screwdriver blade between the darker (or may be metallic) oval trim and the plastic case and pry it off. There are three screws underneath. Remove them and you're in.
It looks to me like they put the FM signal on the ground, so your USB cable and your audio cable are acting like an antenna. Probably best to find the RF output pin and connect directly to that.
Nov 9, 2011. 1:41 PMuhclem says:
I just tried out my Sansi-type transmitter and the results are excellent. I attached a pair of clip leads end-to-end to the ground point and got a clear signal from one end of the house to another. I bet you could cover 1000 ft outdoors with a clear line of sight.
Jul 7, 2011. 12:30 PMitalodisco71 says:
Don't need to open.. if you put usb power with a big cable (70+cm) you can do emit in 100 meter!
Feb 16, 2011. 6:48 PMwilvan says:
Hi Pigmeat,
Is been a while since this trheat was open, anyways I have the same gadget and like 'mdphoenix'' mentioned is correct about opening it.
Now I have a question of my own, not sure if the gadget is the same circuitry is yours..
I need to find the tiny inductor and bypass it to attache antenna.
Thanks and Regards
Wil.
Feb 17, 2011. 8:47 PMwilvan says:
Hi Corrugator, any idea about this item and its boost mod?
Thanks and Regards
Wilson
May 26, 2009. 2:31 PMmdphoenix says:
I know this is a year old but: I have a similar unit. Mine is made by iWave though. The gray bezel around the front comes off and the screws are under there. My board was different but I could still locate the attenuating inductor just above the antenna solder joint. Good luck.
May 28, 2008. 4:10 AMrichms says:
I don't know if you have got anywhere with this, but the one pictured is a hugetide c-007B - the black cover with the < O and > buttons will come off (held on with tape) and there's 3 screws under it. I am still playing with defeating the auto power off on mine, when I have some luck I will post an instructable here.
May 30, 2008. 1:23 AMpigmeat says:
Thanks for this. I have since got another model with a screw and have opened it up. Yet to do any mods as other projects are more urgent.
May 27, 2009. 6:51 AMmdphoenix says:
Out of curiosity, what DO the < o > buttons do on yours? I don't have them, but the spaces for them are under my bezel.
Aug 22, 2011. 12:12 PMmichel23 says:
Just did this mod, on another board.
The first experiment was to extend the antenna. I cut the blue antenna line at 2cm. Soldered a line of 80cm to it. Result: worse than the original tunecast2.
Second experiment: I removed the old antenna (just ripped it off) and soldered a new line to the board on another position, see picture below. Much better result than my first experiment, however, I cannot tell if it's better than the original tunecast2.
Please do not laugh at my soldering technique/result, I'm not very good at this i'm afraid :-)
Third experiment. Note that this step cannot be undone. Using a knife, I cut away that small white thing below my new antenna. It did not seem to make things better or worse. I forgot to make a picture of this, and currently I'm too lazy to reopen the device and take a picture
Tomorrow I'll drive 200+km and will let you know if it made things better or not.
Michel
Aug 23, 2011. 12:46 PMmichel23 says:
Result: it seems to make no difference at all, compared to the original tunecast. Still a lot of noise during playback. I cannot recommend this at the moment
Oct 8, 2011. 7:24 AMmichel23 says:
Initially, it did not seem to make much difference. However, the following made this work fine:
* I drilled a hole to lead the antenna out of the enclosure directly
* Make sure that the sigaret lighter in your car is tightened securely so it cannot move
* make sure that the antenna cable and the power cable are separated well.
These three all caused interference. Having found this out, it makes the Tunecast useable.
Feb 6, 2011. 10:40 PMCapfl2k5 says:
this worked wonders for my little el cheapo 6 dollar transmitter i picked up at a truck stop on a road trip. it wouldnt so much as cause static on an empty station unless it was tucked in the corner of the windsheild by the antenna. But my question is will this shorten battery life any?
Jan 24, 2011. 8:06 PMKurk231 says:
Good Instructable, good pictures and very good details too. The method I used for boosting the signal was as simple as bridging the Inductor (the slightly iridesent black box thingy to the far left of the LCD display) with a wire soldered to either lead, effectively bypassing it without removing it from the PCB. Worked great for me, I've tested it up to 20 feet without adding a new antennae to the FM tuner. I wouldn't be surprised if it's signal strength stays strong even farther than that. Obstructions kill the signal though, if testing with a home stereo's radio, you will find that clear line of sight is key outside of about 2.5-3 meters from the receiver so walls are an issue.
Apr 8, 2009. 4:37 PMferralll says:
I did this on my wife's Tunecast, and now it works great. (or atleast part of it) Before, if you were around a city, you would need a lot of luck to find a good station. Now, I can beat out most of the non major (local) stations! Thatsk. What I did (if any one wants to know) I used a good soldering iron, and some VERY thin gold wire (did at work under a microscope) and just made a shunt around the Inductor that you ripped out (ripped up). It works great, and turned it from almost useless, to very effective. I am now trying to do it to my brother in-laws Belkin TuneFM. (this one is much more difficult to open, and the components are much smaller and closer space. If I get the chance, I will post pictures.
Jan 7, 2010. 11:27 AMwjie20 says:
Hi, was wondering if you have succeeded on the TuneFM? Because I'm also trying to mod mine. Would appreciate if you would guide me in to this.
Jan 10, 2010. 2:39 PMferralll says:
I have tried to do it with the TuneFM.
But it did not work.
I am going to try again once I get some time. I will post something here if I get it to work.  (there are inductors in different places, so I do not know that I did the right one)
Dec 11, 2010. 3:20 AMwjie20 says:
I see, any luck?
Thanks.
Nov 20, 2010. 7:02 PMmaizesmagikarp says:
Actually, I found that soldering the antenna lead to the grey box-like object directly to the left of the old antenna lead gives better results.
Sep 27, 2010. 11:29 PMmeimei250 says:
(removed by author or community request)
Feb 17, 2008. 3:44 PMLumpy_Carpet says:
Sorry if this might be a stupid question, but couldn't one soldier the blue wire to the new connection point and see results?
Apr 27, 2010. 4:21 PMscratchr says:
yes
Nov 7, 2009. 3:38 PMJoby1664 says:
My Tunecast was different to the one in the example when I opened it. I couldn't find the inductor so I soldered the antenna to one of the legs of the transmitter chip which seemed to be producing the signal. Will this produce the same result or have I made a mistake?
I can't see the equivalent components to bypass the auto shut down either.
Feb 21, 2010. 6:52 PMz4c_th3_p4c says:
I have the same problem....
Feb 22, 2010. 1:56 AMJoby1664 says:
The tune cast is a piece of junk anyway. I bought this transmitter in the end, http://www.ccrane.com/radios/fm-transmitters/fm-transmitter.aspx. It's outstanding, plus it's incredibly easy to moify, see here:
http://www.xmfan.com/viewtopic.php?t=3257
They even shipped it to me in the UK with no problems. I would really recommend it 100%.
Feb 3, 2010. 4:58 PMewfw says:
Good old instructables never die.  I have been searching the net for a transmitter.  The reviews on the tunecast are pretty weak, but so is the competition.  What would you say the effective range of this is after the modification?  I want to use this to broadcast a metronome wirelessly to my band.
Dec 25, 2009. 11:02 AMlordjohnnym says:
mpalins.
the british electronic chain store.
finally someone who mentions stuff you can buy in the UK.
most instructables are american or written for americans.
i bought one of thes transmitters from Tesco, for 7 quid last week, and  it seems that the best quality is at the bottom on the fm band, and the best signal is at the top.
ive been also looking for some way of extending the arial, to give it extra range. i was going to increaser the output wattage, but i remembered that it might blow the diodes.
anyway, what i find funny, how mine is technika, and your is belkin, and they both look near enough the same, and have near enought the same layout.
good instrictable otherwise, keep it up. ;)
Dec 15, 2009. 9:34 PMdarkfreedom2 says:
I performed the antenna mod on my friend's tunecast. We are able to broadcast about 45 feet each direction in the cnc machine shop we work in. We now operate a shop radio station off my ipod during the work day.
Dec 6, 2009. 8:24 AMazngiant1212 says:
Does anyone know anything about this iWave FM Transmitter? I bought it at ross and it had a Car usb adaptor thing that came with it. Here are some pics. I will post pics of the inside later. It has a clock, thermometer ( I can see a Fahrenheit thing on the lcd but it displays Celsius. The product didn't have an instruction manual in it so if anyone knows how to change it to Fahrenheit please tell me). It even has a led flashlight :D.
Nov 6, 2009. 3:03 PMgprix1 says:
What did you use for the plastic piece on top of the tripod? How is it holding the transmitter?
Dec 2, 2009. 10:20 PMmixadj says:
 I was wondering the same thing......
1-40 of 165next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
55
Author:Corrugator Supercilii
