Step 4How to boost the FM Transmission power
This step involves a bit of handy soldering which may be a bit tricky.
Should you dare proceed, the procedure is easy enough, simply bypass the tiny inductor. If you refer to the previous step, you would have notice a blue wire soldered to the PCB via hole, conveniently labeled 'ANT', remove this and stick it directly to where the black wire is on the photo below, the inductor can be left connected to one end, just in case you wish to revert the changes.
An adequate length of this black wire for the antenna can be a quarter of the transmission wavelength, in this case, a minimum of 3e8/108e6 * 4 (c = f * lamda), about 70cm.
Now if you wish to take it further, get a telescopic antenna! I have devised a neat way of attaching the antenna, see second photo.
If you live in the UK, Maplin Electronics (www.maplin.co.uk) has a selection of antenna for CB radio
The first experiment was to extend the antenna. I cut the blue antenna line at 2cm. Soldered a line of 80cm to it. Result: worse than the original tunecast2.
Second experiment: I removed the old antenna (just ripped it off) and soldered a new line to the board on another position, see picture below. Much better result than my first experiment, however, I cannot tell if it's better than the original tunecast2.
Please do not laugh at my soldering technique/result, I'm not very good at this i'm afraid :-)
Third experiment. Note that this step cannot be undone. Using a knife, I cut away that small white thing below my new antenna. It did not seem to make things better or worse. I forgot to make a picture of this, and currently I'm too lazy to reopen the device and take a picture
Tomorrow I'll drive 200+km and will let you know if it made things better or not.
Michel
* I drilled a hole to lead the antenna out of the enclosure directly
* Make sure that the sigaret lighter in your car is tightened securely so it cannot move
* make sure that the antenna cable and the power cable are separated well.
These three all caused interference. Having found this out, it makes the Tunecast useable.
But it did not work.
I am going to try again once I get some time. I will post something here if I get it to work. (there are inductors in different places, so I do not know that I did the right one)
Thanks.
I can't see the equivalent components to bypass the auto shut down either.
http://www.xmfan.com/viewtopic.php?t=3257
They even shipped it to me in the UK with no problems. I would really recommend it 100%.
the british electronic chain store.
finally someone who mentions stuff you can buy in the UK.
most instructables are american or written for americans.
i bought one of thes transmitters from Tesco, for 7 quid last week, and it seems that the best quality is at the bottom on the fm band, and the best signal is at the top.
ive been also looking for some way of extending the arial, to give it extra range. i was going to increaser the output wattage, but i remembered that it might blow the diodes.
anyway, what i find funny, how mine is technika, and your is belkin, and they both look near enough the same, and have near enought the same layout.
good instrictable otherwise, keep it up. ;)
If I'm mistaken, someone please let me know. Thx.
I'm having a little difficulty seeing *exactly* where the new antenna wire is being attached or how the inductor was bypassed. Can anyone clarify? Thx.
