Step 5Hmm... How about a longer audio cable?
The solution is to replace the stereo plug with a plug that is small enough to still fit the TuneCast package.
The photo below shows the new stereo plug add-on feature, if you're doing the modification, do note the correct channel, refer to the photo in step 3 for the correct connections.
A brief description:
The white wire is the 'tip' of the plug, which is the left channel, the yellow wire connects to the 'ring' or middle bit of the plug, which is the right channel, the black wire is the ground.
Suitable stereo socket can also be found in Maplin Electronics.
comments
Add Comment
Add Comment
