Belt Sander Wooden Fid
2,029
10
Posted
Introduction: Belt Sander Wooden Fid
A Fid is a Tool for poking in Knots and Rope.
Use it to push aside Strands in Turks Heads or Mats, or open stranded Rope for splicing.
Step 1: Get Some Wood
Find a Piece of Hardwood long enough for your Fid and let it dry.
Step 2: Split Into Quarters
Split the Wood into Quarters.
Use if possible an Axe with an wide Head like a Splitting Maul.
Step 3: Rough Shaping
If you did not split your Hatchet at the first blow,
you could use it now to roughly shape the Wood,
that way you won't need as much sanding as i did.
Step 4: Sand Rectangular
Sand the Sides flat into a rectangular Profile.
Step 5: Sand Octagonal
Sand off the Edges you just created.
Step 6: Sand Round
Turn continuously with light Pressure to create a round Stick.
Step 7: Round One End
While turning slowly lift into an upright Position to create a rounded End.
Step 8: Taper the Other End
Rotate at the round End and press down lightly at the other.
Never try to hold it in Place, if it slips let it fly.
If you wear Gloves be sure they cannot tangle up somewhere and pull you into the Sander.
If you do it with bare Hands, they get very close to the Sanding-Belt, consider using Scrapwood for pressing down.
Step 9: Taper the Tip
When you make a long thin one as in the Picture, leave it thicker at the tip to keep it strong, then taper just the End of the tip.
Step 10: Split the Right Wood
Be sure you split the Wood you found and not the Handle of your Hatchet...
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    2 Comments
    that axe handle almost looks like a find itself ?
    No, standard Handle it comes with.
    https://www.gransforsbruk.com/en/product/gransfors-large-carving-hatchet/
