Bench Flashing a GM PCM
2,668
22
Posted
Introduction: Bench Flashing a GM PCM
Sometimes you just cant get to the car to reflash the ECM. Maybe you want to run a tuning business by mail or your like me and just looking to put something where it just doesn't belong. Like swapping a new fuel injected motor into and old hot rod.
I saw efilive had a nice PDF about bench wiring your PCM. I made a little adapter board just for GM PWM PCM's. This way I can flash a tune and leave the outside work for later....
Step 1: Just the Basics
I added an ALDL connector and a toggle switch for the ignition. In addition to power and ground I only wired pin 2 for the serial data since I only work on older GM stuff. You can add more pins if you want like CAN or GMLAN etc.
I added an alternate PCM connector. Its a 5 pin header that connects to a short cable with RS232 pins on the opposite end. The old RS232 pins fit pretty well onto the GM PCM pins. just cover them with a little shrink tubing and your done.
Step 2: Testing the Interface
Before I trust it to my expensive interface I'll test it out using elmscan and a $12 ELM327 box. If I get a good initialization I'll connect the hp interface next. Then flash a new tune and get it ready to be installed....
Step 3: Other Modules
You can do a similar thing for the other modules from your car. I use the same RS232 pins for the IPC and SIR modules.
The IPC is pretty simple and I just use a small protoboard to get +12V, Ground and Class 2 data to it.....
One of these may end up in my golf cart......
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
You mean a ls2 doesn't belong in a 1987 s10 blazer 4x4. Dang I wish somebody woulda told me 2 years ago.
Nice write up
