Introduction: Bench Grinder Table
About: I am a 21 year old DIY ist and Tinkerer with a deep interest in the field of robotics, electronic and cooking. I am skilled in wood and metal work as well. I work in my basement workshop and i am mostly scratc…
I bought this bench grinder a while back and ever since I wanted to build a table for it. Recently i just had the time to do it. Its pretty simple. Use whatever wood lengths you can get your hands on.
Just follow the instructions and you will be set.
Step 1: Materials
You will need the following
1. Bench Grinder
2. 20 feet length of wood
3. Wood Screws
4. Wood Glue
5. Sheet of Wood
6. Paint
7. Paint Brush
8. Drill machine
9. Sand Paper
Step 2: Cut the Wood
You will need to cut the lengths into pieces of the following length.
4 x 1 ft
4 x 2 ft
4 x 20 inch
Step 3: Make the Wide Sides
First we will make the longer sides. Place the two 20 inch and 2 ft like shows. Drill one of the corner using a 90 degree angle checker. Glue it and screw it. Do the same for the rest of the four. The bottom piece should be 2 inch above the end.
Make a second one just like it.
Step 4: Join Them Together
Join the 1 ft pieces the same way. Make sure to check the angles. Do all sides.
Step 5: Use a Scrap Sheet of Wood
Use a scrap sheet of wood. Or buy it. Attach it.
Step 6: Sand and Paint
Sand using sandpaper and then paint using enamel paint.
Step 7: Attach the Grinder
Place the grinder centered. Mark the spots. Drill it and then bolt it down.
Step 8: Done
