loading
Step 11: An Alternative Solution:
I don't know about you people, but me here where I am, I will have a problem to find the tailstock hardware to put the lathe in motion, and if ever I decide to build this lathe I will have to face a very big dilemma.
One is finding things that will not match exactly, and I will have to ask help from a professional mechanic to fit everything together. That will be very-very costly, time consuming, and it's not worth it.
The other option I have is to import all the necessary hardware and motor from overseas, that also will be costly, so I might as well buy a new factory made lathe and save myself the trouble.
But there's a third solution which I thought about, and I believe it just might do the trick for me or you.
Do you remember those inexpensive Chinese drill presses that you can buy for about 60 dollars?
Maybe if you can get your hands on a second hand drill press?
That will be fantastic.
You will be wondering what to do with the drill press... well a drill press has most of the necessary and matching hardware we need to build the lathe.
It has a strong 400W motor (1/2HP), the two pulleys with the belt, has a strong shaft, bearings and a chuck, so you have almost everything you need and they match together.
Since the pulleys have 5 steps they give the following speeds:
2650 - 1650 - 1220 - 850 - 580 RPM more than enough speed choices for lathe turning.
So there you have it,
a 3 in 1 Bench Lathe - Sander - Grinder/Sharpener
I hope you enjoy the instructable and found it interesting.
If you decide to build it, it will be nice to post some picture and tell us your experience in building and turning with it.
All comments, suggestions, information and ideas are welcome
Stelios L.A. Stavrinides
Nicosia - Cyprus
<p>wish i had pro membership to download the plans :S</p>
<p> superb drawings -well done --</p><p>can you show how to install those Blue lines / T STRIP TRAX </p><p> on the base plywood ?--what do these strips look like -? </p><p>how does one cut a slot to set the metal strips in ? </p><p>are they flush ? show pictures --thanku</p>
Hi Carl, visit this website so you can see how a t track looks, to install it you just make a dado to insert the track flush with the top. I hope this helps you.<br>http://www.ttrackusa.com/Assets/09_images/t%20and%20Miter%20Track/mini_t_w_line.jpg
<p>Carl, Google &quot;T Track&quot; and all will become clear. It is sold in various lengths and has countersunk holes machined into the bottom. It can be inserted into a slot (slot/dado/rabbet/rebate) in the base and fastened with flathead screws. The slot can be made with any number of hand or power tools and is sized to fit the T track and is flush mounted with the surface.</p>
thanku so much ---<br>quite a surprise ---- months later -----<br><br>still in the dark about what the metal ( aluminium?) steel ? <br>T slot strips appearance /size /dimensions ? <br> you showed after illustration ---ie after the metal was put into the <br>wooden slot -----cannot see how the wood<br>plywood is machined /chiselled /routed/sawn in profile <br><br>please can u attach a clear foto close up of the wood channel slot <br>and how the metal fits in ---gave up due to this missing info <br><br>nice job --very professional ---got to get it right <br>thanku again -- Carl
<p>correction here - the bearings of a drill press are not designed to withstand lateral pressures so may fail fairly quickly. But then, finding a couple of good bearings is easier I presume. And the rest - perfect for the job.</p>
<p>Now these particular pieces, the mandrels I assume their name is - they have to be accurate, able to withstand the high RPMs and all the forces tugging at them from all directions, and not fall apart under stress. Needless to say they are the very devil to buy, and very hard to make well any other way. If one day I ever attempt aluminium casting - that would be to make something along these lines..</p>
I live in the bush ---hard to get such fancy metal strips --<br>how can I modify your set up --? I do have aluminium angle iron <br> --mild steel angle iron ----one inch x one inch wide --2 metre long <br><br>how to mill the t slot --?looks complicated<br><br>
<p>stunning project ! well done ----excellent drawings -----</p><p>only problem ---I think you may have to explain what the T strips are-- <br>ie the BED of the lathe --how does one insert /glue those metal strips <br>you call T something <br>you have not shown how they are set into the lathe bed PLYWOOD BASE ---or what they <br>look like --BFORE u make the twin trax---- <br>can u show graphically with those superb drawings how this is done ?</p><p>most cheapo wood lathes have steel 1 inch pipes for a bed ---rather wobbly <br>---I love your design ----please elaborate <br>thanku <br> C A winter</p><p>( how does the tailstock and tool rest bolt /slide up &amp; down on those T STRIPS?</p><p>( cannot see the supporting bolts mounted in the base)</p>
<p>Nice, absolutly Brilliant. I need a cheap solution and this might do the trick.</p>
Great Instructable. I have my motor and will be getting the remaining materials together to build my lathe. I will most probably use some of you ideas found here and some of my own. Your hing on the motor mount as a belt adjustment is pure genius in my book. Thank you so much for taking the time to put your plans on this site.<br>Outstanding!<br>Mike
<p>A great instructable brilliand </p>
Thank you my friend
you have a Greek name so &kappa;&alpha;&lambda;&eta;&sigma;&pi;έ&rho;&alpha; &alpha;&pi;ό &Alpha;&theta;&eta;&nu;&alpha; &kappa;&alpha;&iota; &nu;&alpha; &epsilon;&iota;&sigma;&tau;&epsilon; &kappa;&alpha;&lambda;&alpha; .
<p>absolutely, bloody, marvelous I have looked at your workshop as well as your lathe. Brilliant. I may be moving my worshop onto a houseboat and this would be perfect.</p>
How much time did you spend constructing this project? I am attempting to get approval to build one of the for a small prototyping workshop, my boss likes the component cost but wants to know how many labor hours I would spend building it.
As usual you make excellent Instructable. A lot of good ideas. I really like the way you make the bed of the lathe. More simple than the angled parts. Making a Lathe based on the Shop Notes Issue 73 plans has been on my plans for a while. Finding the hardware is the hardest part. You mention using a drill press for parts, I saw this homemade lathe based on the Shop Notes plans where almost all the drill press is used for the tail stock: <a href="http://woodgears.ca/lathe/homemade.html" rel="nofollow">http://woodgears.ca/lathe/homemade.html&nbsp;</a><br> <br>
Such a great instructable! I hope at some point to have enough space cleared out in the garage to be able to do this. I keep cleaning out the garage and somehow it keeps filling up with junk again.
I will be starting this project with a variable speed 1/3 hp GE motor, I'll post pics!
Hoping you still get these. For the speed control could you use a router speed control like this http://www.harborfreight.com/router-speed-control-43060.html ?
I am not sure as that is a 120V and me I'm using 240V, but I can't see why not, you better ask someone more knowledgeable in electronics. <br>Thanks
&Mu;&pi;&rho;ά&beta;&omicron; &pi;&alpha;&tau;&rho;&iota;ώ&tau;&eta; , &pi;&omicron;&lambda;ύ &kappa;&alpha;&lambda;ό ...&sigma;&upsilon;&nu;έ&chi;&iota;&sigma;&epsilon; έ&tau;&sigma;&iota;...&chi;&alpha;&iota;&rho;&epsilon;&tau;ί&sigma;&mu;&alpha;&tau;&alpha; &alpha;&pi;ό &Kappa;&rho;ή&tau;&eta;.
thanks for this great instructable. <br>Several readers have asked for the SketchUp file(s). <br>I would also like to have the ones for &quot;&quot;The smallest workshop in the world&quot;&quot; instructable, if any. BTW, one of the most awesome Instructables ever posted!!! <br>So, could you please answer if such SketchUp files are available? <br>Thanks again, ron.dacosta@gmail.com
Hi Stelios. Coming here has provided me the impetus to get going and build this. I'm running out of steam and need the minds of others like yourself to accomplish woodworking needs. Big thank you.Tom.
Very cool design &amp; a great set of instructions!! <br> <br>Added to the database at homemadetools.net: http://www.homemadetools.net/3-in-1-woodworking-lathe-sander-grindersharpener <br> <br>Ken
There is a classic book on building a (metal) lathe from scratch, using only hand tools, available from Lindsay's Technical books: <br>http://www.lindsaybks.com/dgjp/djgbk/series/index.html <br>This is a must-have for anyone seriously considering this project. <br>I agree, the grinder is way too fast and expensive; use a 1750RPM appliance motor instead, you can get one from a repair place for around $30.
Great job, congratulations. <br>Thanks for the beautiful instruction! <br>What is missing for you to try out for your project? <br> <br>Any restriction on sharing your Sketchup file? <br> <br>Thanks.
I would like to build one of these with my son as a homeschool project. Do you have a sketchup file of it?
And an excellent project. My question is, how are you going to mount it on that fantastic small workbench you use that Fine Woodwoking Magazine published? Not sure you have enough room left there, although I guess it could be temporarily mounted atop the bench, then stored down below on the bench.
You have answered the question your-self :) <br>In my instructable The Smallest Workshop in the World you can see how and where is supposed to be stored on the multitool bench. <br> <br>Thank you for visiting and commenting <br>Stelios
some motors will work with motor speed controlers. this is i belive a reostate essentiall you dial in the speed you want from high speed to low speed I had one for my dremel tool. Motor speed controlers are available for routers as well so if that will work for some one with a router. I bought one combo mini lath at good will it ran for while then motor desenegrated so i took it apart and built similat pully arrangment to replace motor after finding the machine tool compay went out of business. the usable parts or a similatr lathe are the shaft bearing face plate tail stock and tool rest. always wear full face mask when turning on lathe.
I believe there many other ways to do a lathe and controll its speed. I just try to show one way of doing a low cost lathe. I am not a lathe expert put I beleive that the type of speed controll you will need it depence on the motor you will use. As for the full face mask... I totaly agree with you. Thanks
I think it is way cool and I totally get what you are trying to do. Thank you it is not for the professional but it is for the DIY'ERS. Thanks again
You are very welcome
&nbsp;A grinder is too fast for a power source for a wood lathe using identical step pulleys. &nbsp;A grinder runs around 3000 rpm or more (in the US). &nbsp;This is about the maximum speed you want for a lathe, and you want to be able to get it down to about 500 rpm. &nbsp;With equal pulleys your motor speed would be about the midrange of your lathe speeds making the top speed about 6000 rpm. &nbsp;To use the grinder you would need step pulleys of unequal sizes so that the largest step on the grinder pulley would be about the same diameter as the smallest step on the headstock pulley, or you would need another set of pulleys to reduce the speed down.
<div>Thank you very much for your points.<br /> &nbsp;</div> <div>I am not a lathe expert, and this is why at the end of my instructable I welcome every <span>comment, suggestions, information and ideas.</span></div> <div>Also this is why I was saying in my instructable that the difficult part is to find the right hardware for this project. <br /> &nbsp;</div> <div>The information I found on this, it used a 1/4 HP (1725 RPM) and identical 3 step pulleys and by crossing the belt you get speeds from 4150 to 700 RPM. My grinder is double that speed as you said 2950, so yes it seems that it needs to be reduced either with unequal size of pulleys or another set of pulleys to reduce the speed down. I will look into this.<br /> &nbsp;</div> <div>Anyway because I had my doubts, this is why I came up with the drill press dismantling idea which will give you speeds from 2650 to 580 RPM which I believe might be a good solution to the hardware problem.</div> <div>I will have to correct the instructable according to your remarks.<br /> &nbsp;</div> <div>Thank you very much for the constructive comments on this project</div>
how about using a washing machine motor instead of the grinder? <br>
Yes that can also work as long as you can control your speed. Please have a look at step 3. <br> <br>Thank you for visiting
Thank you for your comment. <br>If you have a look at step 3 that's what is about exectly, pulleys of unequal size. <br>It all comes down to what can you get to build this. As I say in the instructable is even better if you can get a low speed motor or if you have a look at step 11 you will also find an alternative solution using an old inexpensive drill press. <br> <br>Thank you for visiting
Option B is to get a grinder with variable speed already built into it. I bought an inexpensive grinder at Sears that would work pretty good for this project. The only drawback I see is that the speed control is on the front of the grinder, so you would have to set the speed prior to starting your work, unless you feel comfortable doing some work on the grinder and relocating the on/off - speed control face plate to a safer location.
I really like how you hinged the grinder to act as a tensioner for the belt.<br><br>Quite the engineer good sir!
thank you for visiting and commenting
did you make that in google sketch up
Yes V.7pro
cool!
Although I already have 4 lathes, this project is very tempting to build, just to show off at my woodturning club. &quot;Hey, Donna, bet my whole lathe cost less than your Oneway drive spur.&quot;
About This Instructable
214,371views
1,106favorites
License:
Bio: Design Communications Graphic & Web Designer Photography NYIP, PSA ---------------------------------- Woodworking 3D CAD designs Photography Scuba Diving (PADI Assistant Instructor) Iconography Painting Esoteric Studies
More by Steliart - Stelios LA Stavrinides:Pocket Hole Plugs Cutting Sled for the Kreg Jig Kreg Jig Work Platform Idea Sanding Block & Wing Nuts Key
Add instructable to:
