Step 17Tilt Table Feature
In the graphic the three dimensional square is a piece of sturdy plywood. It would be mounted under the table top and above the table base. The red lines show the location of hinges that allow the table to tilt for a bevel cut. The green lines show the location of hinges that allow the blade's cutting depth to be altered.
Wedges or slotted struts would be used to hold desired angles of tilt. The slot in the table top through which the blade passes will need to be altered to make it wider if you are tilting the table top for a bevel cut.
As always, be sure you know how to use a table saw safely. They can be very dangerous during any lapse of attention or unsafe practice. I already like you because you read my Instructable, but I cannot be responsible for any accident or injury you have making and using what is described here. There are plenty of sites on the Internet that describe safe table saw practice.
(Note: If you looked at this step before, I corrected the hinge positions. The previous arrangement would have created problems if both tilts were used at the same time. What is shown now will work.)
comment
Add Comment
Add Comment
