Bench Top Power Supply
Introduction: Bench Top Power Supply
I finally found the time to make my own bench top power supply from and old computer power supply. This has been done many times before and this is my take on it.
What you need
  • Computer Power Supply
  • Screw drivers
  • Wire cutter/Strippers
  • Ring terminals
  • Soldering Iron (If your right terminals aren't crimp type)
  • 4 screw terminal posts (I made my own, Instructable here)
  • Heat shrink Tubing
  • Switch
  • Drill
And as always be careful around power supply's. They contain capacitors that can cause serious harm to yourself if not handled properly.
Step 1: Identifying Wires
For the first step we need to take the case off from around the power supply.
Now you need to identify the wires
  • YELLOW = 12 Volts
  • RED = 5 Volts
  • ORANGE = 3.3 Volts
  • BLACK = Ground
  • Green = Power On
I cut all the other wires back down to the board and wrapped the ends with black tape to prevent them from accidentally touching anything else.
I then sorted the yellow, red, orange and black wires into separate groups.
I set the green wire and one black wire aside for the switch to turn on the power supply.
Step 2: Adding Terminals
Now i selected around 6 wires from each color and trimmed the rest down close to the board and covered with black tape.
The six wires from each color were then soldered into a ring terminal and then covered with heat shrink tubing.
The green wire and the one black wire were wired into the switch.
I then attached my screw post terminals to the ring terminals.
Step 3: Drilling Holes
Mark out on your power supply case where you want your terminals and switch to be. (Since my power supply was smaller and more compact I didn't have much choice where they would fit)
Drill out your holes and test fit your terminals and switch.
Step 4: Button Everything Up
Put your post terminals and switch in there holes and reassemble the case. Now plug in power and test your voltages. You now have a cheap desktop power supply.
I would of liked to have added an led to signal when the power supply was turned on and this could easily be done with an led in series with a resistor connected to one of the voltages.
Thank you for taking the time to read my instructable, have a nice day!
3 People Made This Project!
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
  • Paper Contest 2018
    Paper Contest 2018
thanks for all the details - like color code of the wires etc. This let me build a DC power this afternoon. Plus I added two DC-DC step down adjustable modules with LCD display, so I can get variable voltages apart from the ones provided.
sorry for my poor english but why do you need a load?
It's dependant on the supply.. Most switching supplies, will shut-down if there is no load across the +5V rail to GND.. I think a lot of the newer ATX supplies have this already covered, but a lot of the older ones, (right back to the original IBM-PC 5150), if there was no load, would simply stop working within seconds if there was none. (something about the feedback circuit that regulates the voltages.. If no load or overload, the supply simply shuts-down.)
BTW Joshmt2012, Love the "DefCon" switch application! (flip cover toggle)
good power supply
Excellent. One of the cleanest designs i've seen!
Hi, is the power supply limiting current? and if so by how much from each voltage? And it would not be better to take off all the wires and just put one of each of thicker diameter to reduce cluster arround posts?
How much current is allocated for each rail (voltage) should be written somewhere on your psu. I believe (correct me if im wrong) you should use more wires than one since with one wire you would be using a specific rail and put load only on that while psu are designed to share the load.
I made one. love it. I used color coded terminals though. I don't want to forget or permanent marker to wear off so that's the only change I made. good job.
