Bench-mounted Router Table by jdege
Featured
Step 9: A minor fix
When I first mounted my router to the insert plate, and tested it against the top, I found a problem.  There router has a knob that is used to lock the spindle from spinning, while you use a wrench on the collet.  This knob wouldn't turn, because it ran into the MDF.
It only took a moment to route out enough to make it work.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
