In the bottom of the photo is a hand gripper. You squeeze the unseen handle which pulls a string which pulls the bottom of the gripper part, making the yellow lever pull against the nonmoving arm.. I made a servo version that has three joints so it can grip, move left/right and up/down.
Look at all the sheet metal I had to cut form and bend! So where did the metal come from? What did I need to fabricate it?
Remove these ads by
Signing UpStep 1Raw material and tools
Tools needed is a marker, hammer, and sheet metal cutter or tin snips.
Cut the molding bigger than you need. Bend with plyers any rounded edges (like on the stud), then lay on cement and hammer flat. Make your marks of where you want to make your cut then cut. use a small square so your lines are true.
comment
Add Comment
rimar2000
says:
Add Comment
