Bendable Pole Axial Generator Winding
Published
Introduction: Bendable Pole Axial Generator Winding
This process will detail how to prototype small axial generators for use in wearable products.
Step 1: Parts List
Required Components:
- Bendable Stator Base (http://bit.ly/29NCWC7)
Required Expendables
- 37 AWG Copper Wire (http://bit.ly/29NsZ7w)x
Step 2: Prepare to Wind
Strand out a couple of inches of wire before winding.
Step 3: Wind the Pole
Wrap the wire tightly around the pole. If wound tightly at least 250 winds should be possible on each pole before the wire begins to slip over the outside shoulder.
Step 4: Finish Winding
Strand out a couple inches of wire, then cut the wire. Thread the wire tails through the center of the base and under the pole.
Step 5: Bend the Pole
Once the pole is wound, firmly grasp the winds with fingers or pliers and bend it up 90 degrees. This should be easy to accomplish without damaging the wires - otherwise the base material is too thick.
Step 6: Repeat for All Remaining Poles
Repeat the steps for all remaining poles. Be sure to wrap the wire in the same direction - CW or CCW - for all poles.
Step 7: Solder Wires
Solder the individually wound poles according to the diagram shown in the photo.
For more information, contact us at info@solepowertech.com
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
