3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bendable Tripod
Bendable Tripod
Go anywhere mount anywhere bendable tripod for Camera's and Camcorder's.
Step 1Supplies Needed.
Supplies Needed.
1/4" Bolt 2 1/2" long
1/4" Nut
1/4" Wing Nut
1/4" Washer x 2
1/4" Fender Washer
10 Gague Solid Copper Wire x 2 about 16" Long
First, place a 1/4" washer on the bolt. Then wrap both pieces of wire around the bolt, just above the washer (make sure that the wire is bent in the middle around the bolt). It is important to wrap the wire tight. Then place another 1/4" washer on the bolt, followed by the 1/4" nut. Tighten the nut on the bolt, it's a good idea to use a pair of plyers and pinch the wire tight around the bolt. Once tight, adjust the legs, and it's ready to go.
8 comments
Aug 21, 2010. 1:55 AMkaika says:
I can't see the video.... I have no idea why @_@
Mar 20, 2009. 8:49 AMwakojako says:
Awesome, cheaper, lighter and longer legged than the standard gorilla pod
Jun 12, 2008. 10:17 PMm00dimus says:
Great idea for mounting a camera to the handle bars of an ATV. Thanks
Apr 22, 2008. 8:39 PMbenthekahn says:
Nice instructable! I made a similar one with segmented hose (Gorilla Pod). Check it out and vote for it if you want.
Mar 28, 2008. 4:16 PMvr360 says:
extremely simple and just GREAT! :D it might become somehow disposable after a few uses if the wires aren't too good, but thanks a lot for sharing it!
Jan 25, 2008. 12:40 AMalvincredible says:
genius
Aug 17, 2007. 9:06 AMjamnoopers says:
this is a great flexible tripod you can buy - http://www.joby.com/
Jul 30, 2007. 5:04 PMsudopeople says:
very cool idea, great video! what did you use to narrate it? her voice is pretty close to real!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fishin4daze
