Step 4: Finishing touches.
Check that everything is as the veery simple circuit drawing.
Glue the presets on the board where you want. Out of the mechanical way of the disk, ball, etc.
Now just weld the + and - of the signal to the external audio cable.
Glue everything in place. The LEDS cables under the board, the board and any cable that is loose.
For the last, weld the audio jack at the end of the audio cable.
If you use the 9v battery, weld a plug for it and glue the battery on the mouse.
If you you use a switching DC converter, weld + and - to the thin cables.
Reassamble and its done!
Plug and Play!
Remove these ads by
Signing Up
Not Nice
![WORLDS CHEAPEST VIRTUAL DRUM at $10 [ Rs.500] - using pc ( no drum module required )](http://www.instructables.com/files/deriv/FA7/71UR/GUI0ZWAC/FA771URGUI0ZWAC.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
