3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Best Cat Litter Bike Buckets
Every bike worth its salt has some way to carry cargo, and I am not the first to think of using cat litter buckets. However, I am the best at it. I say this not because I'm egotistic (although I am) but because I have had several buckets fall apart on me, and the next incarnation is always built to remedy the problems of the last generation. What you are about to see is the culmination of years of Cat litter bike buckets, perfect for groceries, bike camping or anything you can imagine.
Step 1Buy Your Cat Litter
Start by gathering your material.
Most of the work is done by the cat litter manufacturer, it's hard to mold your own plastic bucket. In my experience, use one of the buckets that comes with a full lid, not a screw on cap. As well, square sides makes it much easier. My preference is Scoop-Away, but that's more for their quality litter than anything else.
Cut 2 pieces of pipe strap 8 large holes long. Well, 4 if you want to make 2 buckets.
Gather 8 bolts and matching nuts for each bucket. Ideally they should fit snugly through the holes in the pipe strap.
Pannier hooks, whatever you find works best. I have tried a lot and get the best results from 1 3/4 inch L brackets pounded into shape with a hammer.
Eyebolt and corresponding nuts and washers
A drill, screwdriver, and blade makes the work go quicker
For best results, leave a PBS cooking show on in the background while you work.
15 comments
Mar 10, 2012. 12:17 PMmpandolfo says:
Some acetone (nail polish remover) and a little elbow grease will remove the label.
Jul 26, 2010. 11:53 AMbo88y says:
To remove the labels, a belt sander works quickly (10 minutes, but half of that is flipping the bucket and trying to hold it down), but with some smudging from the heat. The resulting "matte" finish (a blatant euphemism) might be prone to collecting road dirt, but some people like that rustic look. You could do it by hand, starting with 80 grit and then hitting it with 120-150. ~ ~ If you sand them off, there are spray paints that stick quite well to plastic (Krylon and Rust-oleum), especially CLEAN, sanded plastic, but leave it alone and let it cure for a week or so. This makes a huge difference in the adhesion. Lots of color choices. Make it pretty. ~ ~ Yeah, I know the instructions say you can use it after an hour, but I used this stuff on recycling bins, and it scratched easily after a couple of hours, but the ones I left alone are still doing fairly well. And that's on the kind of tall, lidded bins that get picked up by the trucks and flipped. On the surface that the trucks' dumping-arm presses against. They're scratched, but no more than any other surface-coating would be scratched. I love this paint. I prepped the painted areas of the bins with 150-grit sanding, and then wiped with a damp rag, BTW, going further than the instructions require.
Apr 18, 2010. 10:53 AMJermi4 says:
Hello it's me again.  Well I finally finished my cat litter panniers and thanks very much for the inspiration!  I took a pretty different design path with cues taken from the Arkel systems for attachment.
My problem now is that I have two huge advertisements for cat litter on my bike.  Have you over your years of experimentation figured out how to get the decals off of these buckets?  I tried GunkOff (basic solvent) but it would have taken many hours and tons of the stuff to do the job.  I heard a heat gun might help.  Any suggestions?  Thanks.
Jan 23, 2010. 10:17 AMurbanmari says:
Hi Fuzz, thanks for this idea of how to re-use cat litter pails.  I don't use clay for our cats but have wanted some reuse for the ones I see discarded.
Quick question: What kind of short rack is that over the front wheel?  Is it specifically made for over-the-front-wheel, or what?  I'm searching models but don't find a bunch.   Thanks!
Jul 30, 2009. 9:11 PMJermi4 says:
How does this add to the strength of the bucket? It seems like some of the designs which incorporate a small piece of lumber would give a lot more strength.
Jul 31, 2009. 12:11 PMJermi4 says:
Okay I understand that. I'm about to build a set of my own though, and I'm concerned with the forces applied to the plastic around the bolts because it's very localized, and very different than then bucket was designed to accept. I was planning on mounting a 1/2" think board just snug underneath the top rim of the bucket so that the forces are distributed along this top lip. The bolts would go through this board as well as the bucket. Do you have any experience/troubles with such a design?
Feb 4, 2009. 5:23 PMfeelgoodlost says:
How do these handle when well loaded on the front? Also, not sure if you have any idea, how much does an empty bucket weigh? Thanks for posting this.
Aug 22, 2008. 4:10 PMBrowncoat says:
I can't tell what you've attached your buckets to, but I don't think my bike's got it. I also can't tell what you've done w/the bungee cord(s). :/
Aug 22, 2008. 6:18 PMBrowncoat says:
Ok, I don't have a bike rack. No wonder I couldn't' see how it could work on my bike, eh?
Aug 17, 2008. 4:42 AMaliceownsj00 says:
what a great idea! Thats probably one reason why I haven't gotten a bike... that and I'm lazy. But the, 'not being able to carry things' is a big draw back from biking!
Aug 16, 2008. 3:40 PMflataffect says:
good reuse/repurpose. If I lived near anywhere i travelled I'd to this with my huge bucket left from laundry detergent.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Fuzz2050
