Best Monitor Backlight!
4,281
13
Posted in TechnologyLeds
Introduction: Best Monitor Backlight!
My PC has an extra 5V cable, so I've decided to use it to built a back-light monitor.
I've seen many back-lights monitors constructed, but none of them used their computers own power.
If you have a useless 5V cable in your PC,  try doing the same.
Step 1: Materials
The materials:
-multimeter
- LED strip (requires 12V input) // I thought about building my own step-up voltage regulator from this tutorial http://www.hobby-hour.com/electronics/lm2577-switching-regulator.php , but I figured out that buying one from ebay would be cheaper and the upside is that you can adjust it to a maximum of 35V which can be used for other projects.
-heat shrink wire
-soldering tools
Step 2: Assembly
1- Cut the led strip to the desired lenght
2- solder it together and to the Voltage regulator (make sure you give it enough wire lengh)
3- stick the led to the monitor
4- plug the voltage regulator to the EXTRA power source of your powersupply
5- Enjoy!
PS: You can add a switch to turn off the light whenever you want.
ThankS!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    Dont you have to worry about heat?
