3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Best Solar Oven
Best Solar Oven
In my Engineering class, my teacher told us that we had to invent or modify something and post it on the Instructables web site. I looked at three or four solar oven, and using their findings and ideas, I built the Ultimate SOLAR OVEN!
This Solar Oven is very cheap and easy to make.  It uses around-the-house items that you use every day.
I hope you enjoy my solar oven.
Ben G.
Step 1What you need!
What you need!
Like I said, almost all the items are things you find around you house.  You will need...
-1 big box (You probably want it to be a square box that is bigger than 2 feet long)
-1 small box  (It should also be square and 4-6 inches smaller than the big box)
-Styrofoam insulation (you can cut it up to fit in the big box)
-Tinfiol
-Black spray paint
-Newspaper
-Glass (One person used glass from a broken scanner.  It will need to be big enough to cover the box.  You can also buy a sheet of glass and use a glass cutter to cut it so it has the right dimensions.)
-Tape or glue
-Glass cleaner
-Pare towel
-Sharpe (who says it can't be pretty)
-Thermometer
-Baking rack (optional)
-Timer (optional)
-If it isn't sunny, you can try a very bright light.  It probably won't work as well.
Once you have gathered all the materials, you may go on to the next step...
18 comments
May 24, 2012. 3:14 PMsxu1 says:
How long did these cookies take to bake? Please respond!!!
May 26, 2011. 9:45 AMpenasagra says:
To keep the flaps in the right position you could join the flaps using either pastic tape (ideally duck tape) or a string set to the right distance.
When the flaps try to fall down, they'll be stopped by the string and will remain at 45 degree angle.
Not very useful if there's wind but...
I hope it helps.
Jul 4, 2011. 11:46 AMjavajunkie1976 says:
Duct tape will release if made to sit in the sun for a long time. The stuff, in my opinion, is useless. The tape you should use is called Gaff tape. Theater set construction crews swear by it as do I. It can be applied and reapplied many times.
Feb 22, 2010. 4:18 PMhefner93 says:
may i have the recipe you used for the cookies for this oven i might be making this for a physics project and do you know how long it would normally take to bake them?
Dec 15, 2010. 11:16 AMwrksnfx says:
Double your cooking time just remember to keep a check on them so they wont burn.
Jun 25, 2010. 4:56 PMBallabirdie says:
@RadiantLux You need the black paint in a solar oven because the color black absorbs light (and therefore, heat) and is essential to make the oven hotter. You could probably find some non-toxic black spray paint, if you are willing to look for a while.
Dec 15, 2010. 11:15 AMwrksnfx says:
Tempura paint, or child-safe or barbecue grill paint as long as the label reads non toxic when dry is what is needed.
Nov 22, 2010. 2:12 PMi c monkey says:
don't put foil on the bottom of the box
Oct 30, 2010. 5:38 PMhyperfocused72 says:
You can *not* use styrofoam for insulation in a solar cooker! They give off toxic fumes! Read the Introductory Manual at htttp://www.solarcooking.org under Solar Cooking: The Basics to find safe alternative ways to insulate your cooker. Then see how you might improve on some of the existing designs. Good luck!
Mar 4, 2010. 12:23 PMTannius says:
 What is the average temperature inside the over? I'm guessing 450 degrees isn't even close other wise the cardboard would combust, also the reason you said to double cooking time.
Sep 22, 2010. 1:34 PMEv says:
I have a manufactured sun oven from http://www.sunoven.com/. It can get to 400f in the summer time. It's an even heat, not like a gas or electric oven which has hot spots. I use regular cooking times. There are some solar recipes on the internet. There are a LOT more crock-pot or slow-cooker recipes that adapt very well to solar cooking.
Sep 22, 2010. 1:28 PMEv says:
Doesn't make sense to paint it black then cover with aluminum foil. I say skip the painting step. You DO want to put black cooking pots in it to convert the light energy into heat. Solar cooking recipes even say you can bake a potato by putting it in a black cotton sock!
Aug 12, 2010. 9:26 AMLawst says:
To position the reflectors and hold them in place use sticks. Either tape them into position or stick them into the ground at the height you need.
Jun 15, 2010. 12:42 PMRadiantLux says:
Your next step will cover the box with foil. Why do you need to paint it? I would rather not add the toxins to m y oven. Does it make a difference?
Jul 16, 2010. 4:37 AMZeBadger says:
I don't think that you are supposed to put foil on the bottom... but the black in the photograph looks rather grey :/
Jun 19, 2010. 3:09 PMsarahann826 says:
does the glass go on the very top of the box on the inside, or does it go on the bottom under the rack? I didn't understand that part.  Love the idea and will definitely try this.  Thanks.
May 20, 2010. 1:47 PMthisismin3 says:
is it possible to use a substitute for black spray paint, such as dark blue?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ben1122
i rock
