Step 3Bake at 500F for 30 Minutes
The pan will smoke a bit during this process. That is completely fine and natural, your oven will not catch fire.
The hot flax seed oil will smell a bit strange. That is also completely fine and natural, the smell will go away.
PRESS ON!
People are often instructed to turn the pan upside down because they almost always put too much oil in the pan. If you wipe the oil out of the pan (just leaving a *light* coating) there is no need to invert the pan. Inverting the pan may also be somewhat counterproductive. The goal is to fill the pits and then have the oil carbonize filling in those pits. If it's inverted the oil is more like to come out of those pits and collect on the high points. With enough coating those pits will eventually fill in but you'll end up with a rougher surface than you would otherwise.
Thanks so much for this idea.
