3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Best Way to Season Cast Iron Pans - Flax Seed Oil
Step 4Repeat 4 to 7 Times
Repeat 4 to 7 Times
Once you've "cooked" the pan for 30 minutes, remove it from the oven and let the pan sit until it's cool enough to touch.  When you're sure it's not still hot, reapply a thin coat of oil using the same method described in step 2, put it back into the oven and cook it for another half an hour.
Keep repeating this process until you've gone through as many cycles as you'd like.  I've found that 4 to 7 rounds was enough to result in a semi-gloss, beautifully smooth, tough, black finish that is ready for use.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
882
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
