But when it comes to watching video or using apps like musical instruments or DJ app's, it's not quite fitting. Mostly you want to use the iPad in landscape mode, which is impossible with the keyboard dock. Of course you can buy stands supporting it both ways, but all of what i could find was designed to work on a flat, solid surface.
I thought about my needs and finally came up with this thing...
Remove these ads by
Signing UpStep 1You will need...
- a microphone stand, with a small and at the same time not to light base
- a soft grip microphone clamp (so it doesn't shatter from the screws)
- an iPad car mount (or anything else that holds your iPad and can be screwed on to something)
- two screws of a reasonable size (this depends on your particular materials)
Putting things together is quite easy, just saw off the two sides of the clamp like seen in the picture.
You want to cut off the same amount on both sides, to have it mounted perpendicular later.
Then, put in screws to fix the car mount to the microphone clamp.
And done!
comments
Add Comment
zazenergy
says:
Add Comment
