3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Better Book Safe
Better Book Safe
I wanted a book safe and didn't like the versions that I saw that looked like they were hacked out with a rusty hatchet. So I came up with my own way of making one.
Materials needed
Thick book - find a book that will look like it belongs in the bookshelf. Don't put "The Works of Shakespear" in a shelf with electronics books just because it was the right size. It looks out of place. Better to use that book "10,000 Electronic Diagrams" that you never use anymore. You can get really nice thick well built books for free or very cheaply at garage sales, library sales, old book shops or just around the house. Just ask for permission if it's not your book.
A sharp utility knife or single edge razor blade or exactco knife
Band saw (recommended) or coping saw (useable)
6 min. epoxy or thin super glue - I like 6 min. epoxy because it is thick and will stay where you put it and I'm sensitive to the fumes of super glue.
Strong cloth or paper to reinforce the binding if necessary.
Step 1Removing The Cover
Removing The Cover
Lets get started!
The better book will have a binding that looks like this. The cover of the spine is separate from the actual spine of the book and you can just cut down the hinge line and separate the cover from the pages.
If the cover is not separate from the spine carefully peel it away after you have cut at the hinge line.
95 comments
1-40 of 95next »
Oct 6, 2011. 6:49 PMtrevyboy says:
can you use a jig-saw?
Dec 29, 2009. 10:09 AMEntropy_king says:
Neodymium magnets from an old CD/DVD drive would be VERY strong, you would just have to "indent" an area and epoxy them in... I think they are 1/8" think too.. so its still very covert. The more magnets you use along the edge the stronger the closed position will be, but also that much harder to open.
Sep 27, 2011. 11:44 AMjmhoward says:
What a clever idea! Using magnets along the closed edge would keep the book from being inadvertently opened.
Sep 27, 2011. 2:48 PMEntropy_king says:
Thank you! This was fun to build
Aug 16, 2011. 8:36 AMpmcbruce says:
Nice one mate. Was planning on doing something like this with a book on, business statistics or some rubbish, to put my netbook in when I travel through crazier places like south america or simply for the fun of having your netbook inside such an awesome cover - but taking the pages out and using a bandsaw, i never thought of that - brilliant.
Feb 16, 2011. 7:12 AMiPodGuy says:
This is awesome!
For the past couple of months I've been setting up a geocaching program for the county library system and I've been hollowing out a lot of books with an Xacto knife. I'm to the point where I'm absolutely sick of it.
Now I just have to dig out my old bandsaw and buy a new blade.
Perfect!
Jan 14, 2011. 2:42 PMDaniel.Overgaard.Nielsen says:
Awesome for an external hard drive cover! :3
Dec 6, 2010. 7:02 PMchrisandamanda says:
I really like this Instructable that I am going to use for a Geocache in a Public Library. Thanks for the Idea how to do it.
Dec 25, 2010. 10:56 PMlug big lug says:
AWESOME idea.... Is there a copyright? bc i am gunna use it
May 7, 2010. 4:40 PMtbcross says:
please don't use Shakespeare even if your bookshelf is loaded with classics, it just seems wrong... :)
May 8, 2010. 7:49 AMtbcross says:
:) that's cool I have some old text books that would work. The ex was a teacher and of course those got left behind. lol
Mar 20, 2010. 2:57 PMpeacemaker5000 says:
nice and simple and you dont have to cut each page with a knife thanks
Dec 15, 2009. 1:21 PMddavel544 says:
Pretty cleaver, don't have a band-saw....but my regular electric hand saw should work just as well.  Will just have to check the floor and look for my left thumb.....
Jan 29, 2010. 7:12 AMstephenniall says:
And my dad wonders how that burn the size of a soldering iron was on the kitchen table and why a chunk is missing
Jan 29, 2010. 10:01 AMstephenniall says:
Ooh good excuse .. Just have to explain i fed my termites Jigsaw blades and thats why it looks like its from a jigsaw
Oct 16, 2009. 9:20 AMLoki_Peverell says:
This is awesome and sooooooo easy! And now I will finally have a use for the bandsaw my uncle left in the basement when he moved out!
Dec 9, 2009. 5:07 PMr42xer says:
God u guys are arguing over what would happen if your tie got stuck in a band saw. thats really cool btw
Oct 20, 2009. 9:14 AMwenpherd says:
Never wear a tie when operating a bandsaw, if it gets cought in the blade its over.
Jul 4, 2010. 10:23 AMaaronscottaugustinhotmail.com says:
Wow your arguments are pointless... Wear a clip on.....
Jul 5, 2010. 6:16 AMwenpherd says:
Or just be safe and not wear a tie.
Dec 7, 2009. 10:51 PMneeds_more_to_do says:
 So wait, a silk tie is stronger than my entire upper body and back? My back would break before the tie would shred?
just double checking.
Dec 8, 2009. 10:59 AMwenpherd says:
No, the tie would pull you into the blade and rip your face to shreds.
Dec 8, 2009. 6:03 PMneeds_more_to_do says:
1) Except that I'm pretty sure I'm stronger than the tie...
2) The motor, while having a high power, low rpm (the way one would be pulled into the blade) on the input is converted to high rpm and low power for the output to the blade...
2.5) ...and if you've ever held a loose blade in your hands you'd know how light they are. the same as when you stop a fan blade with your hand. momentum and mass go hand in hand. just because it's going fast doesn't mean it's unstoppable.
3) There is also a handy-dandy device called a blade guard that only exposes a designated section of the blade. unless your guard is set at a foot above the table of the saw or your face is two inches high i see no possible way to saw ones face with a bandsaw.
I don't mean to sound rude i just don't like it when people take what they learned in shop class and expect it to be the 100% truth.
Oct 1, 2010. 2:05 PMworleyll says:
Lathe? a lathe has alot more power than a bandsaw!
Jan 18, 2010. 8:30 PMneeds_more_to_do says:
In now way did I imply that I am invincible and in no way did i suggest that one should wear whatever around the shop. It is definitely important to keep loose ends clear however, I think I was pretty clear stating that my point was to dispel the myth that Tie + Saw = Face-shred.
So before you jump to conclusions why don't you go ahead and SCROLL UP.
Apr 21, 2010. 7:38 PMneeds_more_to_do says:
lolwut
Sep 8, 2010. 8:03 PMkibbler says:
I believe that means YOU LOSE
Sep 12, 2010. 5:11 PMneeds_more_to_do says:
Wow really quick on the draw huh buddy. Good thing i was just waiting for some one to reply.
Sep 13, 2010. 1:55 PMkibbler says:
No problem. I'm to help
Dec 9, 2009. 3:25 PMwenpherd says:
Well I didn't learn that in shop class cause I never took one, and it still is not a good idea anyway.
1-40 of 95next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:Re-design(The Answer Jar)
