3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Better CPU Cooling
Better CPU Cooling
After some recent google-ing and computer upgrades I have discovered a way to get your CPU up to 7 degrees Celsius cooler.
Step 1Parts Needed
Parts Needed
For this instructable you will need the following
a $5-$10 80mm or bigger case/CPU fan (I used a 92mm cooler master CPU fan)
a dremel with a with a metal grinding disk or any similar tool
a spare 3 or 4 pin fan spot on your mother board *note: 4 pin fans work on 3 pin spots*
$1 garbage bag ties
eye protection
Speedfan (program)
***If your case does not have holes or some ventilation in front of the CPU fan area you might have to cut a hole and put some mesh or something there***
**If you don't have a spare 3 or 4 pin can spot you can spend an extra 10 dollars to get a fan like this one Arctic Cooling Arctic F9 PWM 92mm case fan**
10 comments
Jan 16, 2011. 7:44 PM_Scratch_ says:
My CPU cooler cant move any air, so my case heats up to about 100-110 degees F, i just use the case as a foot warmer under my desk a lot of the time...
Apr 13, 2011. 4:35 PM_Scratch_ says:
edit- i now have a crazy case and fan and my cpu never goes above 20degrees C under a max load
Oct 25, 2010. 6:06 PMegammoc says:
those fans on these sinks SUCK!!!!!!!! i had a wire get caught in one of mine, i was like scew that and put in and old intercoolor sink i had
Aug 6, 2010. 10:57 AMScott_Tx says:
Well, that's an interesting way to add a casefan.While you're hacking on it you might as well cut out a circle under the fan for better airflow.
Aug 7, 2010. 10:56 AMScott_Tx says:
I've got a 120mm on the outside of mine. I used a drill to make screw holes and tin snips to cut out a circled in the middle. The power line goes in through the big fan hole. Use the fan itself as a template for the hole. I used nails to mark the spots to drill screw holes and drew a circle around the blades inside the fan to mark the big hole.
Aug 6, 2010. 4:31 PMGreatSage says:
If you are looking for better CPU cooling, look into something called water cooling.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:knex hitman gill
