loading
Step 4: Remove USB Connector from Junk Electronics
Disassemble your piece of scrap electronics, and remove the USB connector.
to do so, first lay a piece of desoldering braid across the set of 4 soldered pins that transmit the USB data. Heat the back of the desoldering braid until it is removing the tinning from the soldering iron. Using a pair of tweezers, carefully lift the braid away from each solder pad, while still applying heat.
Next use either a fresh piece of desoldering braid or a desoldering bulb to remove the large legs that hold the usb connector to the board. you will also need to bend the legs outward, just a bit.
apply upward force on the connector, while heating the pads where necessary to break the remaining bonds.
re-tin the leads, and remove any lumps of old, hard solder.
Instead of killing an entire controller, would this be possible to open the xbox and take out a port and replace it with the female usb?
Although the controller is not killed... in fact, after splicing a male usb on it, the controller works on Computer and Xbox... you could easily add a usb to the xbox... or do what I eventually did... on controller ports 2,3, and 4, I wired a relay to switch when a connection between ground and shield on the controller port and switches the four usb-compatible wires between the controller port and an it sensor on port 2 and usb ports on port 3 and 4... it was a complicated hack, but it makes loading data, using a remote, and gaming practically peripheral free
<p>So I get the basic concept of how this would work but I'd like to see your implementation. I realize your post here is quite old, but if you are able I'd love to see how you incorporated that relay. Thanks! </p>
after reading comments for what was about twenty minutes, I decided to just leave a comment. possibly I overlooked, but if looks aren't concerned, it would be possible to open to controller cord and splice the USB connector wires to the appropriate xbox controller wires thus also leaving the yellow wire untouched.... right?
Meny people have had issue with using action replay. I found this program that will search for xfat devices and allow you to easily insert files onto them. Its called Xplorer360_extreme2.
I made one out of a busted memory card. Works well. Even got some people wanting them. May have a business here.
Thank you. Made one today following your instruction. Couldn't thank you enough
Any suggestions on how to be extra careful in avoiding detinnig or breaking the traces?
just made one of these myself... looks just like the one in the picture... works great!
How does one "test" it? Sorry, kind of a newb.
i tested mine useing the product of this instructable<br>http://www.instructables.com/id/XBOX-Controler-Via-Usb/
Just plug the adapter into you Xbox and see if you can get it to work before you super glue it back together cause it would be very hard to get it back apart after you had done so.
works great soldered it wrong twice i guess i should read more hahah but my xbox is kinda picky when it came to the flash drives
I'm 99% sure i got the wiring correct, but my adapter gets SUPER hot after about 1 minute of use and i cannot get any of my flash drives to be recognized by my xbox any suggestions?<br />
What kind of controller do you have? Different controllers may change which wires go where a bit.. What you describe sounds like the wires not being hooked up correctly. For me it was just trial and error, finally got it hooked up right by accident.<br />
In a fit of rage I thought of this, and made it. Instead of soldering the female end directly to the dongle I used paperclips to extend the reach of the tiny pins. J-J-Jam it in as they say. with the paperclips a small hole at the end of the dongle the size of the usb was all that was needed.<br />
so if i plug this into the xbox, the xbox hardrive will be erased?<br />
nevermind, it formats the flash drive<br />
&nbsp;Alright, this is kind of a dumb question, but I gotta make sure!<br /> <br /> I did all the wiring, and when I connect my 512 MB Micro SD through a USB adapter it recognizes it, but it says it's damaged. Does that mean that I got the wiring right? Or is that a problem with the USB storage? I'm gonna buy some other cheap usb drives later, so I need to know If I got it right at least! So if &nbsp;the xbox is recognizing it, does that mean i got the wiring right?<br /> <br /> <br /> <br />
I don't know for sure, but what do you mean by it says it's damaged?<br /> Does it actually use the word &quot;damaged&quot;, or does it say &quot;there was an error. the drive has been erased&quot;?<br /> <br /> If it actually uses the word damaged, then I don't know for sure, but I&nbsp;would guess that either the wiring is wrong, or the XBox doesn't accept that type or something.<br /> <br /> Although, with mine I got the wiring wrong the first time and it didn't say anything. It just didn't work.. <br /> <br /> I would try a USB&nbsp;drive and see what that says.<br />
I&nbsp;had some problems getting my XBox to read my flash drive at first, but then I realized my controller was a cheap copy, and the wires where different colors than a normal controller cord (I actually left some cord on it, I didn't feel like soldering it like you did). So I switched them around a bit and got that working (first flash drive I tried worked, woo!).<br /> <br /> Then I had problems getting the MaxDrive to install to the flash drive, and after trying about 20 times, finally figured out it just wouldn't work on my 32-bit Windows 7 laptop and tried it on my older XP&nbsp;desktop, which worked instantly.<br /> <br /> I actually did a few other things, too. I&nbsp;added a male USB connector to the end of the controller cord, so I can still use that controller on the XBox. And as a added bonus, it works on my computer, too! (With XBCD&nbsp;as a driver, and installed JoyToKey, a mouse/keyboard emulator.)<br />
Hey Guys I used 5 different usb flash drives but seems like my xbox wont like them...LED inside will flash but nothing else is happening...<br /> any advice?<br /> I used 2- 1Gb 1-4Gb and 2-2Gb....Im getting crazy here...<br /> help please
Perhaps you got the wiring wrong?&nbsp;thats what happened to mine.<br />
Whenever I try to update the driver it says "Windows has determined that your driver has the best software" I'm running vista. If anyone could help me with that could you please reply.
Go to control panel, then to device manager, find your "mass usb storage device", right click it and choose "update driver software". Then choose "browse my computer for software", then click on "let me pick from a list of drivers on my computer", click on the usb mass storege device and then click "have disk", browse for the xbreader.inf file you modified, load it, and it will successfully update it. it is doesn't work then you're doing something wrong.
that's why! Vista has some wierd problem with it because IT'S VISTA!!!!!! WHY USE VISTA?!?!?!?!?!?! I'm done. Try it on a different computer, or if you have a big hard drive, make a dual-boot environment and have XP as a 2nd system. Works fine on XP
<rant> DEATH TO VISTA!!!! </end rant>
Or: <b><b><b><h1><big><big>DIE VISTA!!!</big></big></h1></b></b></b>
no, <rant> death to all techies using vista </rant>
o god no, please dont do it!! ;-]
do you use vista?
yeah, i personaly think it is better than all the others, just the stuff in my computer, and the bars telling you how mich space you haved used, ant the search bar on the start button =] do you use Vista??<br/>
i do too, but i hate it...the looks are nice and so is the search bad but UAC is a pain, and speed on a quad core with 4 gigs of ram pssht, its like windows '95....i'd rather use linux or xp....hopefully 7 will fix some of this...
vista may such but compared to 98 it is great i finally upgraded<br/>it is also great if u dont have $100 to spend on xp<br/><strong>wait for 7!!</strong><br/>
i meant suck not such
ah..
im not sure if you meant '98 or you were quoting me in which case you meant '95 ...anywho, i like Xp over Vista and i like Ubuntu over them all...
by 98 i meant windows 98
mhkay, wasn't sure
Can I put a usb in it and my xbox will recognise it as a memory card so i can use action replay thanks
Only certain usb sticks are recognized by the XBOX. I have 3 usb sticks but my xbox will only recognize a generic fourth-party chinese usb drive I got from wal-mart.
i tryed an iomega external zip 100 it dosent give me a broken card message but it dosent work<br/><strong>WHY I ASK, WHY!!!!</strong><br/>
Very nice! But when your done programming a flash drive with this...You can Make it direct. By soldering the drive to the xbox male port... So you can give it a nice casing and\or use it on multiple xboxes...
When i try to save the XBreader.inf it says that i'm not the administrator when i am. This isn't really related to the soldering or anything but i want to know how i can fix this for so it works.
My cousin, who is really good with xbox's did the original bunch of electrical tape way. That's before I found this way, now I will work with him to make one or two of these things.
Wow, damn yeah that is way better then what I did for mine lol. Bunch of wires wrapped in electrical tape.
This definitely looks much better than the electrical taped xbox to usb cables... but I have a question: If I use this to connect an external USB hard drive to a softmodded xbox with XBMC running, can I run my home videos and music from the external USB Hard Drive? Or to put it another way, If I build this adapter and connect a USB Hard Drive to my Xbox, will XBMC recognize it as a source to run videos, music and photos? or will I still have to transfer the files to the internal hard drive first? thanks, SF
About This Instructable
188,452views
98favorites
License:
Bio: I'm a self proclaimed renaissance man. My goal in life is to have a conversational/practical knowledge of every subject known to man. I ... More »
More by gschoppe:The AnonyBox - A cheap and easy network device to manage anonymity online Jack-o-lanterns from years past Heart-Shaped Paperclips
Add instructable to:
