Bi Color LED Driver Circuit | Using 555 Timer IC | DIY | Easy | 5mm LED | Electronic Project
Published
Introduction: Bi Color LED Driver Circuit | Using 555 Timer IC | DIY | Easy | 5mm LED | Electronic Project
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today In This Tutorial I Am Going To Show You Step By Step ( Home Made )
How to make Bi Color LED Driver Circuit with the help of 555 Timer -- IC.
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
Please Subscribe ↪ https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
Step 1: Hardware Required
  • 1. NE55 Timer IC
  • 2. Bi Color LED
  • 3. 10uf Capacitor
  • 4. 33k Resistor
  • 5. 4.7k Resistor
  • 6. 10k Resistor
  • 7. 220 Resistor
  • 8. BC557
  • 9. 9V Battery + Clip
  • 10. Breadboard
  • 11. Jumper Wires
Step 2: Circuit Diagram
Step 3: Working Explanation
Hi in this circuit 555 timer ic is use to generate a specific pulse at output pin number 3
this pulse will gice high and low signal due to which the bi color led glow once red and once green
a transistor is used to amplify the output current to drive led
You can set any delay for ON OFF using different value of capacitors
Thanks
Step 4:
    • Microcontroller Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
