3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bias lighting on the cheap
In this instructable, I'll show you how to install bias lighting on your LCD monitor. Bias lighting can really help to improve your perception of contrast, and make panel monitors much easier on the eyes.
Step 1This is simple
This is simple
Most expensive bias lights are 6500K (which is the colour tempature of white on nearly all LCD and Plasma screens) Fortunately, most daylight simulation bulbs are that too.
For this you'll need :
1 cheap clip on spotlight (mine came from Ikea)
1 C clamp
1 Daylight flouroescent bulb
Easy really just clamp the C clamp on the rear of the arm of your monitor, you're looking to get it as central as you can. Then fix the spotlight onto the clamp. It's got to throw light evenly behind your monitor when on.
Then fit bulb, and switch on.
38 comments
Aug 22, 2011. 8:08 PMtheness says:
this is pretty cool. but i also looked up bias lighting and found a product that is designed for it. it's called the antec 6 LED lighting. i think it's listed at $12 bucks, but i got mine for 9 at amazon.com. has anyone else used their product? i think it's pretty decent since i play in low light settings.
Mar 10, 2007. 11:13 AMmfacer says:
Bought two cold cathodes and wired them up to the molex power cables inside the PC... the photos are not very good - but it really does make a difference when working in the dark!! (at the moment they are held on the back with insulation tape... very high tech!)
Jul 3, 2008. 8:15 AMchully says:
It makes me wonder: If I've already got a cold cathode light inside my monitor, why get another one to tape on the back? Is there any chance I could draw light out from the internal backlight to bias the screen? To be worth it, The backlight must still do its original job at 100% capacity.
Jul 24, 2010. 4:05 PMuberchoob says:
Only problem with this is that the case keeps all that light radiating in the right direction and keeping making sure you don't see things behind the LCD. If the case was removed, the LCD would be seen as semitransparent instead of a solid image, which might actually be kinda cool, like a minority report kind of thing. This is a long time since you've posted this. Have you tried it out??
Oct 11, 2008. 2:51 PMdavidprosser says:
I'd remove the back cover of your monitor and see what light comes out - you never know, it could work!
Feb 18, 2009. 8:35 PMbwahacker says:
I am using two $10 gooseneck lamps from Target behind my monitors. I just point them up and away from the screen to illuminate the walls/ceiling behind the screens. One of them has an 11 watt yellow-ish CFL from Home Depot, the other one has a 6 watt white-ish CFL, also from Home Depot. Both of them are on X10 controllers so I can control them from sitting down without getting up and walking around the desk. Not very hacky, I suppose, but works well enough.
Nov 9, 2008. 8:00 AMjj32x says:
£15 for the bulb??? thats expensive. we get them for free and the most iv ever seen them cost is £5.
Oct 11, 2008. 11:32 AMhcold says:
Haha, I've had the same set up behind a big old CRT cabinet TV, and it provides enough light so it's not stressful on the eyes, but not distracting from what I'm watching. Lovely.
Jul 10, 2008. 1:04 AMssokolow says:
Heh. I actually set up something similar to this without having a clue that there was a name for it or why it made computing at night more comfortable for me. I'll probably switch to yours now though. My current setup is a full-spectrum desk lamp pointing at the wall with a wire tied to the touch-knob and it'd be nice to have something strapped to the back of the monitor arm (dual monitor setup with a home-built monitor arm using a pair of $5 VESA-standard mounting plates off eBay) and a proper switch.
Jan 2, 2008. 5:12 AMHitman101 says:
I made a little youtube video on this subject. Gave you guys proper credz too.
http://www.youtube.com/watch?v=HVzVJhklN30
Aug 5, 2007. 3:57 AMwetnap says:
a nice cheap alternative that still looks good from the side is a cheap grono lamp from ikea. it is a rectangular open top block of translucent glass.
Jul 10, 2007. 11:28 PMbobparker says:
Nice information on the science. As I was reading this I was inspired to try putting LED string along the back edge of the desk - provides 2 benefits, 'backlights' the wall, and makes it possible to see under the desk (with a monitor on top of the desk, of course there is a computer under the desk). Should be low watts. The trick of course will be to easily secure the light string to the desk edge.
May 22, 2007. 12:19 PMdchall8 says:
I'm trying this with a 5-watt CF bulb at 2640K temp. It is a mini bulb supposedly made for inside refrigerators. Normally my office has two overhead 12-watt CF bulbs, of the same color. I'll try this backlighting just to change things up. My business is to transcribe data from paper to a database, so the overhead light is a must. The mood light will be for after hours and watching TV. I put the 5-watt bulb in a trouble light I had sitting idle in the garage. The cord is only 18 inches long so it fits perfectly plugged into the power strip for my router and DSL modem. Normally the steel shielding on a trouble light is hotternblazes, but this runs at room temp. Does the bulb color make that much difference if you have red walls?
Mar 5, 2007. 5:00 PMmfacer says:
I really like this idea... I wonder if you could wire up the lights using the power from the PC? I have a cold cathode lying around from the old modding days - now wondering whether it'd be an option to buy a few white ones and use those - although, they'd be on all the time - unless you add a breaker switch maybe.... possible you think?
Mar 5, 2007. 5:13 PMjnixon says:
That's easy to do with almost any kind of switch. Likewise, you could do the mod describe above and add a switch to the line.
Mar 5, 2007. 6:00 PMmfacer says:
another thing - can you buy 1metre long molex leads?! Or would you have to make your own possibly?
Mar 5, 2007. 5:56 PMmfacer says:
what's the power output from the PC power cables.. I mean, could you plug a standard desk lamp for example to these?
Jan 1, 2007. 7:47 AMMr.Devious says:
This would create a nice mod, but it's not exactly bias lighting, bias lighting changes colour based on whats on the screen, this is simply just white light meant to match that of the lcd.
Aug 28, 2006. 1:09 AMcommandercool says:
I have looked everywhere for this bulb and I can't find it. Where did you get yours? What are some alternatives?
Aug 29, 2006. 11:57 PMcommandercool says:
Oh ok, thanks. I'll try looking for it. Unfortunately, I'm from the States so I can't order it from that site. =(
Aug 30, 2006. 4:07 AMcommandercool says:
Yeah, I went to a Home Depot, and believe it or not, they didn't have it! In fact, they only had one bulb with the right base, but it was too dim to be of any use. An entire aisle with of light bulbs and you would expect them to carry something similar!
Aug 22, 2006. 9:01 PMspinach_dip says:
Aug 23, 2006. 2:11 AMkarmaghost says:
That's really cool, but if I searched correctly, a set of 4 (of which you used 3) would run you $50 (plus shipping, tax, etc.), which is at least twice as much as this setup.
Aug 22, 2006. 1:47 PMMDWeezer says:
Is this as effective when the display is almost right up to a wall? I've got a 20" dell display and I really like this concept, if anything I'll get a result like this Panasonic TV's. Worth a shot anyway, I often work with the light off in my office (which is off my living room, with a large entrance) but it has track lighting and those suckers are like spot lights and heat up real quick so I prefer working with them off.
Aug 22, 2006. 1:04 PMtobobo says:
Here's my version of it. My lamp isn't as good but I already owned it so I just used what I had.
http://beta.zooomr.com/photos/tobobo/153443
Aug 22, 2006. 9:35 AMJaDe says:
Is that a The Legend of Zelda/Link Wallscroll I see hanging on your wall? ;-) BTW, is there some kind if science behind this? I would really be intersted in how this actually works. -JaDe
Aug 22, 2006. 12:16 PMcrabs says:
The science behind this is that it's easier to focus on something if it is brighter than the environment (which is why the frame of that lcd is black and cinemas turn down the lights when the movie starts). Backlighting like this also makes you exercise your eyes by focusing at different distances (lcd-wall behind) which is nice :)
Aug 19, 2006. 12:31 PMikarias says:
This looks cool and simple. but i wonder if it really works. Seems to me that you still sit in a dark room looking at a lit screen.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bowdie
