3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Biased lighting for your big screen tv
I was intrigued by the instructable explaining how to add biased lighting to your LCD monitor.
My monitors are CRT and sit in a spot that does not allow biased lighting, but my big screen TV could be a candidate.
Now I can watch TV for hours on end without eye-strain.
Step 1Inspiration
Inspiration
Biased lighting on the cheap gave me this idea, so essentially this is his instructable, modified for my situation.
Check out his tutorial here. http://www.instructables.com/id/EE79YDCL0REQZJI1AZ/
This is a pic from his tutorial below.
After the jump is my how-to.
27 comments
Jul 17, 2010. 10:10 PMsloleak says:
"My only annoyance is the thermostat above the TV. It makes the whole setup look silly." I had the same problem. Went up into the attic and found that the thermostat wires were fed down from the top wall plates. I cut the wires (2 in my case), spliced more wire on and was able to move the thermostat over. Drilled thru the wall plates and fished the wires down to a new location. Only had to use 2 beers...:) note: First check with a stud finder to insure there is no blocking between wall studs at the new location.
Oct 13, 2007. 6:05 AMFrogz says:
you owe me $4000, i just tried this and my 70 inch hd dlp tv stopped working
Jan 25, 2008. 9:14 PMbensharn says:
don't you feel partially responsible? After all ColumbusGEEK even stated how dumb he was being. Instead of sticking a drill in your $4000 tv you could perhaps try tape. (that eliminates the whole drilling part into the $4000 tv part)
Jan 26, 2008. 12:00 AMFrogz says:
check arrived safely do you recomend a bigger drill bit? i think that was my problem
Jan 26, 2008. 12:23 AMFrogz says:
are you sure? i actually used the next model up from that, it comes with an second full sized handle so a second person can hold it steady
Mar 27, 2009. 4:27 AMcornflaker says:
Yeah pfft. handles are as useless as instructions.
Jan 12, 2008. 8:22 AMjakecav04 says:
lies
Oct 15, 2007. 12:01 PMVIPER2475 says:
Dont DRILL into you TV! Just put a small lamp behind it.
Dec 1, 2006. 12:05 PMjoeny1980 says:
I dont have an LCD or anything that would use this but ever since I've seen commercials for the Philips LCD tv with "Ambilight". I thought - how hard could that be to make with some LEDs. Someone needs to build one of these with adaptive lighting - changing colors based on the picture on the tv. I'm not an electronics genius but here is an idea on how to do it: Take the video out of the tv, connect it to the smallest least expensive screen you can (maybe $50 LCD for a car). Pump up the brightness and saturation and contrast on the screen of the LCD. Mount some fiberoptic tubes on the front and string them to the edges of the back of the tv facing the wall. Thats my ghetto-rig idea. Better yet, somehow take the video output of the tv and essentially color block it out and translate that into light a multicolor RGB LED.
Dec 30, 2006. 7:21 PMstarphire says:
The Philips light is a set of cold cathode fluorescent tubes, so the colors are not nearly as saturated as LEDs would be. Color Kinetics patented this concept for use with RGB LEDs some years ago.
Dec 24, 2006. 1:11 AMIbanezfoo says:
I am trying this out on my 55" LCD projection TV. So far it is more annoying than anything. I think it is too bright. I used the same bulb you used in this guide. I am going to try and wire up some kind of dimming circuit and see if that makes a difference.
Dec 24, 2006. 1:14 AMIbanezfoo says:
Actually I realized right after typing this that you can't dim flourescent bulbs, well not easily anyway. The LED route might be a better solution.
Oct 18, 2006. 8:55 AMrule001 says:
hmm, don't really see the point in doing this :( light behind your screen actually makes the sceen seem smaller! This is the reason most screens have a black frame, silver or no frame also makes it look smaller. also, my big screen has economical settings: the brightness of the sceen adapts to the light of the enviroment. So the darker the room is, the lower my electric bill gets ;) But fot those who (for some weird reason) think this is the coolest thing since tv was invented... ..just hang x-mas lights behind your screen! U can get them in a color to mach your room, they don't get hot and they use practicly no power so u save on your electric bill too.
Oct 4, 2006. 5:11 PMA3rd.Zero says:
That looks really good. You may want to invest in a light that produces 6500K, and some sort of neutral photo grey paint for the wall behind the TV. Otherwise your eyes will adapt to the color temperature of the biasing source which conflicts with the color temperature of your TV.
Sep 22, 2006. 8:08 AMjoeyjoeyjoey says:
Great how to. If I may add... another way to acheive this is to use under cabinet lighting. I have found LED ones at my local harware depot. They are thin and allow themselves to be applied with velcro (so no need to drill). Its great option for those with minimal clearance as well. As far as your orange cast on your photos. If your camera has selectable white balance select tungsten.
Sep 7, 2006. 10:41 AMjeffroward says:
this is pretty awesome. although, i have some questions- isn't the lightbulb visible when you walk from the tv room to the kitchen (or whatever room that is) ? have you shrouded the bulb for a more... aesthetic...look? and, have you adjusted your thermostat to account for all the heat the tv and the bulb put off? seems like the heat would cause you to have bogus temp. readings. other than that, this is an awesome idea!
Sep 7, 2006. 12:31 PMjordan.day says:
While I'm sure the TV puts off some heat, he pointed out in the instructable that he used a 9W compact flourescent bulb -- so the heat it generates is pretty negligible, and probably dissipates quite a bit by the time it gets to the thermostat.
Sep 7, 2006. 5:58 AMbowdie says:
Nice work sir! Although the photo of the screw sinking into the TV is still giving me the heebies.
Sep 6, 2006. 10:16 PMFrenchCrawler says:
Nice, but if you were really worried about damaging your TV, why not just attach a board to the back of the stand and then attach the light to the board? Then if your tv broke for some reason and you buy a new tv, you can easily switch out the old and put the new one in without drilling holes into it.
Sep 6, 2006. 10:13 PMtrebuchet03 says:
That's pretty cool :D Good way to use another instructable to your specs ;) A
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:ColumbusGEEK
High Life drinker, tinkerer, and all things ending in *er.
