3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bible Marking Pens
Bible Marking Pens
These represent a sampling of most of the pens I have used for making notations on the thin paper used to print Bibles.  They are a fountain pen with red ink and an extra fine point, a dry mark pencil, a 0.2mm crafter's pen, and a red ballpoint.
Step 1The Problem
The Problem
This is a page from a Bible I use often.  The paper is so thin that a faint image of the factory print from the other side of the page is almost legible.  Although I did not make any notations on this page, I did highlight some cross reference listings with a yellow dry marker pencil.  A dry marker pencil is good for highlighting, but useless for making one's own notations.  Dry marker pencils come in quite a variety of colors.  They need frequent sharpening, but there is no danger they will go through the paper.
14 comments
Dec 11, 2011. 10:54 PMmynd_games says:
I underline and write in my Bibles a great deal and over the years I have found plenty of things that did and did not work. There was a lively discussion and some great information to be found at :
http://www.bibledesignblog.com/2008/12/bleeding-through-the-sorry-state-of-bible-paper.html
I have had great results with Pigma Micron pens. They have a variety of tip sizes from .05 mm and up, as well as many colors. I use blue, black, orange and green. I have a thinline bible and for underlining I like the 0.3 or 0.5 size just fine and for writing I like the smallest .05 size.
Sep 23, 2011. 11:25 AMoverblast says:
As in, a list of types to avoid, a list of types recommended, in sets of types of use. For example, a brand of kit pens we could look for or just a general term for it. Thanks!!
Sep 23, 2011. 11:21 AMoverblast says:
What pen brands should be avoided, which do you recommend?
Aug 7, 2011. 10:28 AMaesipov says:
Thank you very much for the article: My cross
Apr 20, 2011. 9:54 PMmole1 says:
You've clearly done some serious research here. Bible paper is very strange stuff. I think only one mill in North America makes it.
I used pencil on Topaz India Paper forty plus years ago, and it's still there without any apparent change. Is there a reason you don't use a 0.5 mm B lead?
Apr 21, 2011. 11:25 PMmole1 says:
I'm not trying to convert you or anything, but I just checked... the only notes still legible in my great grandmother's Bible are the ones in pencil. There were some in blue fountain pen ink that were almost gone when I was a child. Those are now blank paper. I think graphite is much less subject to chemical change than most inks.
Perhaps the shuffling of your professor's notes resulted in repeated rubbing of slightly textured paper on the graphite to the point of smudging or nearly erasing it. He would have been writing in an age before micro leads. It takes a lot of effort to make a solid line with an even slightly dull pencil. His point is well taken. Indelible ink would have been better in that situation.
A few years ago I did light fastness tests on Derwent's Graphitint colored pencils. The colors are beautiful and all more or less the same darkness as regular graphite. In less than ten days, through double pane windows, facing west, in December, in Seattle, many lost all color and were reduced to nothing but grays.
Apr 22, 2011. 11:40 PMmole1 says:
Oh! I bet you're right about the washable blue ink. I know my mother used that kind with a dip pen in the 1950's.
To see if your ink is actually bleeding through (being absorbed through) the paper, try putting a black piece of paper behind part of a page of your Bible. If your notes on the back of the page don't show up as darker than what would normally by white space on the page in the area that has the black paper under it, it may be that the paper is just very translucent. You may be experiencing 'show through' of dark values. Red, black, dark blue, brown, and purple have very similar dark values. Using a lighter value color of ink might help.
I prefer underlining to highlighting in texts. Berol Prismacolor colored pencils work well for me because they are soft enough to leave a mark easily. There is no bleed through in regular books. (Dark purple on the last page of my Bible did show through like the original printed ink.) In texts, colors with lighter values work better for me. .. yellow ochre, orange, canary yellow, bright green. I'll try some of those later and let you know about show through. If anyone inherits my Bible, they may wonder for a long time about all the colors on the last page.
Apr 20, 2011. 11:05 PMlemonie says:
Yes it can be thin, I've known of people roll cigarettes with hotel-bible pages  (morally-corrupt as that may be)
Do you think testing pens on cigarette rolling-papers would be a good idea, if the paper-grade is a good match?
L
Apr 21, 2011. 1:31 PMlemonie says:
I had heard that before. True or otherwise, it makes the point that books are for reading, with an aim to learn something.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
