Remove these ads by
Signing UpStep 1What You'll Need
1 x Reflector Mount (a friendly bike shop will give these away for free)
1 x Shim for reflector mount (also probably free at your LBS)
1 x 2 inch 1/4" x 20 thread count screw of your choice (pretty standard for most cameras)
2 x 1/4" wing nuts
2 x 1/4" washers
2 x 1/4" rubber washers
You might also need a drill with a 1/4" drill bit
The video is somewhat acceptable on smooth roads, but I wouldn't want to go anywhere near a trial. It's not the fault of the mount so much as the weight of the camera. The L20 is a pretty compact model, but it still weighs too much to hold steady, and I bet other similarly sized cameras will have the same issue.
http://www.instructables.com/id/Updated-Bicycle-mounted-steadicam/
