Bicycle Camera Mount for under $1
Mount almost any camera that accepts a screw in tripod for under a buck, using stuff you may already even have.
Step 1What You'll Need
What You\
What you'll need to make it:
1 x Reflector Mount (a friendly bike shop will give these away for free)
1 x Shim for reflector mount (also probably free at your LBS)
1 x 2 inch 1/4" x 20 thread count screw of your choice (pretty standard for most cameras)
2 x 1/4" wing nuts
2 x 1/4" washers
2 x 1/4" rubber washers
You might also need a drill with a 1/4" drill bit
29 comments
Apr 24, 2008. 11:50 PMA_Str8 says:
Thanks for the tutorial. I just made one and it works great! I made a video walkthrough as I put it together
Dec 30, 2011. 2:29 PMBikerBill74 says:
Here are some pictures I took of what I did.
IMG_5764.JPGIMG_5766.JPGIMG_5767.JPGIMG_5769.JPGIMG_5770.JPGIMG_5771.JPGIMG_5772.JPGIMG_5773.JPGIMG_5774.JPG
Dec 30, 2011. 2:16 PMBikerBill74 says:
Thanks. This video really helped me, even though it cost me a little under $5.
Mar 26, 2009. 8:45 PMpovertyonwheels says:
great video! thanks.
Nov 27, 2008. 7:17 PMscottredd says:
Nice video.
Nov 27, 2011. 1:25 AMsbhatla says:
i am planning to make a strong one for my D3000.
Nov 27, 2011. 1:24 AMsbhatla says:
What If u add a small spring between the top flynut and rubber washer for extra stability
Sep 14, 2011. 6:26 PMbwoodward1 says:
It actually cost me $2.35 to build, being that I had the free reflector mount. Still not bad at all, and its plenty sturdy for my Mino Ultra.
Mar 17, 2010. 5:47 PMf3rg says:
I tried this out, and the results weren't very promising.  Even with everything as tight as possible, the camera (a Nikon L20) shook enough that you can hear the sound of it shaking on the mic.
The video is somewhat acceptable on smooth roads, but I wouldn't want to go anywhere near a trial.  It's not the fault of the mount so much as the weight of the camera.  The L20 is a pretty compact model, but it still weighs too much to hold steady, and I bet other similarly sized cameras will have the same issue.
May 31, 2011. 5:16 PMjar0n says:
a little late, but you're probably looking for something like this..
http://www.instructables.com/id/Updated-Bicycle-mounted-steadicam/
Mar 20, 2011. 2:12 AMrocky502 says:
This is more of a reply to f3rg, no matter what you do you are always gonna get movement on camera. I made this and it's great, I go mountain biking and use this. Yes I get a rough video but its fun. The other way to film your ride is a helmet mount, then it only sees what your looking at.
Aug 23, 2010. 6:42 AMrazorE500s says:
To Help Prevent it from slipping AND to make it more shockprof wrap some foam tape under it.
Feb 15, 2010. 7:13 AMryanstan says:
to stop it from slipping, try adding a cut-up bicycle tube around the inside of the reflector mount.  Then, you can really tighten the crap out of the screw and the tubes will press against the bars, therefore keeping it from slipping and sliding.  Great idea!  It works perfectly on a Scott Sportster
Aug 18, 2009. 6:53 PMmacguy787 says:
i just made one for less than a buck. beautiful. if anyone wants a photo, just let me know.
Oct 28, 2009. 11:15 AMsharlston says:
me please
Apr 11, 2009. 11:06 AMdre0101 says:
Just made one today. Brilliant. Thanks
Mar 26, 2009. 8:46 PMpovertyonwheels says:
effing fantastic! thank you!
Jan 6, 2009. 3:08 AMGraham9470 says:
You're the man! I'm off right now to go and make one.
Mar 23, 2009. 8:55 AMYates_94 says:
if you made the mount, can you please tell me if it is fairly shockproof, will it slip or snap if you go over many bumps/jumps, i only have a small camera so it is not as if i will be using an slr or anything!
Mar 23, 2009. 8:53 AMYates_94 says:
nice instructable, but to anybody who has made this, is it fairly shockproof, as in if it went over a few drops and bumps with a camera on top would it slip or snap.
Sweet and simple. I like it.
Oct 25, 2008. 12:00 PMdrjaymez says:
Very solid. Could absolutely be used for a GPS. Using an Aiptek A-HD and the video is too bumpy for me to use. If I had image stabilization I suspect it would be much better.
Sep 17, 2008. 12:52 PMbillsquared says:
Great Instructable. I put this together with a Canon camera hacked with CHDK (http://chdk.wikia.com/wiki/CHDK) to shoot one frame every ten seconds over the course of a six-day bicycle tour. The stop-motion results -- sped up from 6FPM to 6FPS -- can be found at http://www.youtube.com/user/bikebillsquared
Oct 7, 2007. 4:07 PMHandsome-Ryan says:
you got a +1 from me because I wouldn't have thought to ask the bike shop for a reflector mount. Nice instructable.
Aug 5, 2008. 5:17 PMFunkybutt says:
Hey pjax, i've got a garmin mounted on mine. Great for unknown places. But the garmin mount is very different from this one.
Jun 16, 2008. 6:10 PMmzim says:
I was trying to mount my Sony DCR SR42 Handycam using something similar when I stumbled onto this page. I tried this variation and lo and behold, the steadiest video yet! This mount works great. Not completely without shakes over bumps but hey.....its a bump for Petes sake. This one gets my vote
May 8, 2008. 6:25 PMbkf11 says:
Just a quick note to say that this is absolutely brilliant. The use of the wingnuts to tighten the bolt in place and the camera is very clever. I'll definitely keep this in mind for the future. Benjamin
Jun 11, 2007. 6:14 AMpjax says:
would you suggest mounting my GPS/PDA on a mountain bike?
Jun 6, 2007. 4:38 PMi.am.mozman says:
I was just thinking about how to mount my gps unit on the cheap. I think this approach may work for it as well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:MikeIsOrganic
