3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bicycle Cleaning
Bicycle Cleaning
Completely cleaning a bicycle is either expensive and time consuming or knowledge intensive. Here is a cheap and fast method for cleaning your bike.
This method allows you to clean the frame, gears, derailleurs, chain and wheels without taking parts off the bike.
Step 1Collect tools
collect tools
You will need a degreaser (I use shout the laundry cleaner), a power washer, oil (do not use wd40) and a wet dry vac.
25 comments
Aug 8, 2010. 11:28 AMForest of Cheem says:
andikam is right. Do not power wash your bike as some bearings (like those around the derailleurs, etc.) are not made to handle that kind of water pressure. They will start to leak water into them and lead to corrosion. A simple sponge and maybe a soft bristled brush (like a toothbrush) combined with soapy water (Dawn is great) are all that is needed.
Oct 31, 2007. 11:27 PMjohnfischer06 says:
i highly suggest NOT to use a pressure washer at all, especially if the bike is above 300 bucks. Your bike has numerous rotating parts, therefore numerous bearings (headset, cranks, wheels). Using pressurized water can force grit into the bearings, therefore ruining your good stuff over a period of time. if really dirty, simply get a bucket of warm water, soap isn't even necessary, and a rag to just wash it off.
Jun 22, 2010. 9:06 PMjavandyck says:
I agree. I did this once years ago. My crank made grinding feel and noise after. Not a good thing.
Oct 5, 2009. 12:13 PMandikam says:
Oh my god please don't power hose your bike as instructed here. It can cause serious damage for anyone that is unsure about what they are doing. Use soap water instead or wait for mud to dry and then simple cycle around on the road for a bit and the main bulk will fall off. I repeat don't power hose unless you know exactly what you are doing!
Sep 21, 2009. 12:03 AMsharlston says:
using a pressure washer can force water into the bearings causing the grease to be pushed out and the bearings to rust
May 31, 2007. 6:15 AMbritman says:
as soon as i saw the pressure washer i thought how bad this is for the bike all you really need is a bucket and a sponge and use the same stuff you wash your car with and not dishwashing soap thats bad too but then again if you like repacking with new grease every time you wash go ahead
Jul 18, 2009. 8:47 AMtheburn7 says:
It only takes 20 secs, srsly with a pressure washer, and of course it sounds like you havent used one before. Pressure washers are machines that pressurise water and spit it out at high speeds, and ususally adjustable speeds. Don't shoot where the bearings are, and it is all good.
Mar 12, 2009. 12:32 AMI smell bacon says:
I would just wipe the mud off and maybe hose down, but i do a thourough cleaning every month or so.
Apr 3, 2008. 5:50 PMcsnyder says:
I only use the pressure washer to clean up a dirty bike before COMPLETE dissassembly. You don't want water and dirt driven into bearings, and even sealed bearings on bikes are not well enough sealed to use a pressure washer
Mar 31, 2008. 3:58 PMzom b says:
i'll just agree with the rest of the people who have said using a pressure washer on a bicycle is not a good idea, and generally unnecessary. maintenance, elbow grease and a little patience is far better than blasting your bike with high pressure water!
Feb 28, 2008. 9:11 PMrooplaw says:
The only problem with this is that the power washer can blow degreaser into the seals and degrease your bearings. Just need to be sure to not spray the bottom bracket, swingarm (mtn. bike), and axles or freehubs.
Oct 12, 2006. 11:36 PMShadowFacsimile says:
Even something as high-pressured as a garden hose with a nozzle can drive debris and particulate matter into sealed bearings and cause everything from slightly gritty handling to serious component corrosion. My team manager told us to douse our bikes with water from a bucket and use time, elbow grease, and eco-friendly degreaser to clean the frame and components.
Sep 27, 2007. 8:46 PMjongscx says:
Agreed, jets of water can often do more harm than good. logic as follows: -If you know this, you'd be the kind to clean your bike meticulously in the proper way, so you don't really need a pressure washer. -If you're thinking of using a pressure washer, you wanted something quick and easy and are probably not the type that will know how to fix a serious problem that will stem from this.
Aug 24, 2007. 1:31 PMpooboy says:
where do i buy elbow grease? jkjk
Sep 11, 2007. 8:21 PMDigi says:
What do yall think about a chain cleaner tool like this one:
http://www.finishlineusa.com/products/chain-cleaner.htm
I use a similar one along with orange degreaser. I can run that sucker through 20 different cycles (no pun intended) of about 10 revolutions each cycle, and there is junk still coming out of the chain. It seems like it might be getting it TOO clean. Afterwards I run it through a couple cycles of water (to clean out the degreaser), get as much water out after, and then lube the chain. Have yall heard anything bad about using a chain cleaning tool of this sort? This is on my MTB by the way...
Sep 27, 2007. 8:42 PMjongscx says:
yeah, basically, that's just a way of automating the "getting-intimately-acquainted-with-your-bike-and-a-toothbrush" method of cleaning. I've used it before. clipped it on and had the bike in a stand while I turned the pedal slowly with one hand and dripped cleaner with the other. It was a "rescued" bike, so it had all sorts of nastiness on it, rust and just regular gunk... got rid of most of it, so it resembled something safe and presentable.
Aug 23, 2007. 6:51 PMampdavolts says:
GoJo white creme hand cleaner: It is soft white soap in an excess of water, plus a bit of low-odor mineral spirits (which is a partial water repellant). -It's safe for hands, non toxic, been around a hundred years. -Soft soap is an excellent degreaser. -Soft soap is a lubricant, largely preventing grit from scratching paintwork -It leaves a beautiful rich shine -it cleans all manner of dirt and oil from all kinds of surfaces, safely -it de-smudges your stainless refrigerator -it de-greases your bike chain Get one of those soft "u" shaped brushes from the auto parts store -dip the brush in GoJo (white creme variety only--not pumice, not "orange action" -Apply to rims, spokes, paintwork, etc. -Slop it on the chain too, and after brushing everything else, attack the gritty chain -Air dry the bike in the breeze of an electric fan--or in the hot sun NOTE: almost all bike frames and parts take on water, "sealed" or not. So any kind of washing is liable to put some water into bearing points. This is why savvy people put a zerk fitting to the bottom bracket, to hubs, and pump in waterproof synthetic grease "Green Grease" is a fine brand. And such a bike and be put into water with no ill effects, just rinse if it was salt water. GoJo (and any identical competing brand) is the most useful all purpose cleaner-- it will make garage sale finds look like new It will make old tired finishes revive in appearance. Use the brush, GoJo and wipe furniture items clean with paper towels; no need to rinse. I've used this stuff for thirty years to clean everything from interior paint, marble, butcherblock (it sucks dirt right out of the pores). GoJo costs a buck per pound tub in the auto parts stores here. I've never seen anyone else extoll its virtues--so i tell about GoJo whenever the topic of cleaning comes up. I no longer use any other household cleaner very much. Dawn is still the best dish detergent. But for de-greasing that grungy kitchen sink, GoJo and a green pad can't be beat. You can do a lot with GoJo. But now you know that!
Aug 23, 2007. 6:56 PMampdavolts says:
I forgot to say, if the item can be rinsed with water (the bike), then fine, that's the easiest. But if you can't rinse, or don't want to add water to the item (woodwork), no need to rinse, just wipe off the dirt and let the remainder remain. A slick, glossy surface will result on smooth items, and a satin gloss on satin items, etc. BTW, anyone ever come across an antique radio, for instance--of Bakelite? Never use any strong (caustic) cleaner. No 409--you'd strip the gloss. GoJo is safe for everthing. I'm a fan of cheap microfiber cloths too. Auto parts stores have the GoJo, the inexpensive brush, the cheap cloths. Good luck, and write me if you disagree or find fault with my advices? Thanks, Reid
Aug 1, 2007. 1:08 AMVelo Apocalypse says:
Y'all's concerns about vulnerable cup-and-cone wheel bearings and bottom bracket bearings can be somewhat avoided by wrapping rag scraps around the bike's "sensitive, cup-and-cone parts." By the way, the old style cup-and-cone spindles are no longer being made, so we will all be using cartridge units soon enough, and these offer better protection. Still, I would 'not use this method. I recommend using a bucket of water, several varieties of brushes, a rag, and Dawn. The bike can be dried using compressed air, if you have a compressor and keep the psi low and the nozzle several inches away (otherwise you may be kissing some paint bye-bye, especially if you have repainted the bike). Otherwise just use a towel. There is very little that rusts on bikes these days save a few nuts and bolts--and a trip to the hardware store for some stainless steel can solve that problem.
Jun 22, 2007. 9:05 PMadamlorenz says:
shop rat here... please, please, please, continue to power wash your bikes [*cough* sarcasm] it is when people do this that the next thought is, why does my bike look so good yet sound so bad???
- 409, or some sort of soap and water combo in a spray bottle for cleaner...
- citrus degreaser
- apply your favorite lube [hopefully some sort of teflon-based, waxed-based, heck, even soil-based]
- heck you could even use some window cleaner on the rims to help deep clean the braking surface.
and as i believe guns-n-roses said it best...
'have a little patience'
May 18, 2007. 6:37 AMSophiRoseyHeather says:
Heather keeps her bicycle squeaky clean!
x
Sep 26, 2006. 1:47 AMuh oh says:
Why is the bike you're riding different from the one you cleaned? Please don't don't tell me you pressure washed that sweet looking road bike
Jul 12, 2006. 11:48 AMjordan.day says:
I have to agree with dan here -- using a pressue washer on a bike is bad news. The sort of person who would use this method is also the sort of person that (I'm guessing) doesn't have the inclination to re-grease their hubs or, in the case of older or lower-end bikes, their non-sealed cartridge bottom bracket. Just saying "don't use tight focus" isn't enough warning, either -- even using your standard garden hose can cause damage in the long run.
Jul 3, 2006. 4:20 PMdan says:
hmm, i'm a bit hesitant to use a pressure washer on a bike because it will get water into all the sealed bearings (bottom bracket, headset, hubs)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tomfolkes(Ultra Job)
I studied computer science at the University of Maryland. I have done computer projects for NASA, various defense and intelligence agencies, AOL, UUNET ect. I am currently working on a project which...
more »
