Step 9Finished assembly and use
iImage Information
Sandwich the aluminum squares around the wire frame and the mirror's swivel ball. Clamp with the screw. Use a toothed washer to keep the nut from working loose. Tighten the screw and nut enough that the mirror stays where you want it. Leave it also loose enough that you can adjust it while riding your bike. I find the mirror works well for me if I can just see a bit of my ear in it. That gives me a reference point for what I see in the mirror. It is not a problem if you adjust the mirror so that you need to incline your head just slightly to see the traffic lane fully. If necessary, you can tweak the bends in the wire frame to get the mirror roughly where you need it and then do the fine adjustments with the swivel features of the mirror and the aluminum squares.
I have been using one of these for quite a while and really like it.
