This is a pretty simple and quick way to build a bike hoist that will lift a bike evenly and easily out of your way. The neat trick is that it uses one rope to lift the bike evenly from two points which helps it lift easily and uses pulley magic to reduce the weight of the bike for the hoister. No power tools required although a drill is handy.
This setup would also work for a kayak or canoe if you had a longer beam.
Remove these ads by
Signing UpStep 1Gather Supplies
- 5' or so 2x4 or a rafter that you can attach this stuff to
- (2) larger hooks that will hold bike. I did not end up using the ones in this pic - i ended up bending my own out of 3/8 aluminum stock from Hope Depot. Lots of options here (see hook page).
- (1) 50' length of rope. I used 3/8th inch poly (something that is softish but does not stretch much).
- (5) pulleys to fit the rope. Pulleys should all have swivel heads (two of mine did not...) and be one size larger than the rope will fit through. This give you some leeway for safety..
- (3) hooks with wood screw threads (basically monster sized cup hooks) and/or:
- (1) eye bolts that is the same size as the hooks above (you can use eye bolt style hooks for all four depending on what you have on hand).
- one drill bit that is the slightly smaller than the core of the hook shank (ie the size of the bolt if you ground off the actual threads) - err on the size of small...
- Brackets to attach hoist to ceiling - i used 2x12 rafter hangers which are $2 each at Home Depot.
Depending on your hardware, you might also need a propane torch (nothing fancy - just the small one...
- some utility screws/drywall screws (the duct tape of fasteners) or decent sized nails.
A few wrenches or something to help you bend the hooks (ie bench vice)
- Ladder and someone to hold it while you monkey around.
- Optional equipment: cheapo carabiners (like the $2 100 lb rated ones from home depot), lighter to fix rope ends, etc.
The main problem I have is I tried to hang a boat that was heavier on one end and it doesn't work because the heavy end will not lift until the light end reaches the top. Does anyone know of a pulley arrangement that does not do this?
There are a few bike hoists available that use a double-rope system, yielding a mechanical advantage of 2. These allow independent control of the front and rear pulleys. The disadvantage of these is, the mechanical advantage of 2 allows one to lift only about 50 pounds before serious hand-pain ensues.
The double-rope bike hoists currently available are:
1) "Sport Solutions Up and Away Deluxe Hoist System" available on amazon.com for $53.99
2)"Kayak / Canoe Lift Hoist by RAD Sportz" available on amazon.com for $34.95
3) "BAC Industries PH-01 Storage Pulley Hoist, 100-Pound Capacity" available on amazon.com for $49.99
1. I've always thought that heating up the metal weakens it, though maybe in this application it is no bog deal.
2. The entire weight of the load is suspended only by the threads of the eye hooks into the wood. Not sure that will last forever and could be catastrophic if it pulled out. I'm running a threaded eye hook through a pre-drilled hole (actually I'm using unistrut but a hole drilled through the 2x4 depicted here would work just as well). A big fat washer and nut keeps it from ever having a change of pulling out. This, and the method of fastening to the ceiling are super important. Make sure they are robust.
Great instructable!
Using 2 rope slings to lift the bike. A pulley fixed securely to the overhead, with rope with a hook on one end, Run the rope through the pulley, and connect to the slings on the bike to the hook and hoist it up.
One more thing. The hooks should have enough weight to descent to the floor when they are not carrying anything. Otherwise it could be a problem to pull them down when they are somehow pulled all the way up. What do you think?
http://www.costco.com/Browse/Product.aspx?Prodid=33784&whse=BC&topnav=&browse=&lang=en-US&s=1
i am using it to lift a 14 foot kevlar (<32lb) canoe to a 12 foot ceiling, i was afraid that there wouldn't be enough included rope, but there was.
peter
http://www.duckworksmagazine.com/06/howto/cleats/index.htm
consider a http://www.boatersworld.com/product/467303087msk.htm
