Introduction: Bicycle Led Light
Picture of Bicycle Led Light
Many times. I used the bicycle in the night and I dont have a lights!. So i decided a make a circuit that blink leds with few components and also very easy.
I also want the light, once installed, to be invisible and the back part of the seat offered a small space
Step 1: Choose the Retroreflector
Picture of Choose the Retroreflector
I have 2 retroreflectores so I decided to use the biggest one that allows me to leave the pcb embedded and it is also red!
Step 2: The Circuit and Materials
Picture of The Circuit and Materials
since my goal was to use few components, use a ne555 ic as a hysteretic oscillator with which I achieve approximately 7 Hz. I used a 555 ic because works with low voltages like those of a li-ion battery.
I used the following materials:
  • ne555 smd
  • 1 10k resistor 0603
  • 1 10uF 6.3v capacitor
  • 5 red led 0805 smd
  • 5 220 resistor 0805
  • 1 old battery from smartphone
  • 1 small pcb 1x2.4 in
Step 3: Make the PCB and Connect Wires
Picture of Make the PCB and Connect Wires
I had never made a circuit with smd components, first soldered the LEDs and their resistors and then the ne555 ic, the 10k resistor and the 10uf capacitor.
Finally, solder wire to the pcb.
Step 4: Solder Connectors and Works?
Picture of Solder Connectors and Works?
solder some connectors to the wires of the battery and the pcb.
just need to close the circuit, will it work?
Step 5: It Works!
it works! :D
Step 6: Install in the Seat
Picture of Install in the Seat
just remain install all it, the pcb and the battery.
the pcb hold it at pressure by the retroreflector.
the battery is hold it with 2 zip ties to the back of the seat
Step 7: All Done!
Picture of All Done!
the led light finished and running in the bicycle.
Step 8: Final Note
I did not use any switch so when I do not use it, I disconnect. But it would be a good idea to place a switch to avoid connecting it backwards and damaging it.
The pcb in principle I did it with a marker, but then I made a pcb in eagle that is seen in step 2, here is
DIY Hacks and How Tos (author)2018-01-13
Looks great. Way better than paying $30 for a mediocre commercial bike like.
About This Instructable
157views
3favorites
License:
Bio: Hi! I'm a colombian, living in Bogota and actually I'm student and maker :D
More by JeffersonM23:Bicycle Led Light
Add instructable to:
