Bicycle Light Steampunk Style
Don't be too harsh on me, this is my first instructable! YAY Instructable.
This is a project I completed a little over a year ago, I wanted to redo my Schwinn World Tourist mainly to get rid of a little bit of surface rust, but decided it need an updated, or rather dated, look.
My apologies as I don't have pics of each individual step, because well, I didn't know I would be writing an instructable on it.
This was a little contest, my girlfriend stated that I never finish any project that I start, so we set a date and the bike had to be finished by then. I will explain in a little detail what all i did to the bike here as this instructable is about the light fixtures I put on it.
I completely disassembled the entire bike, sanded and painted everything. For extra durability on my time consuming paint and scrollwork job, I took it to the paint shop at work (I work at a body shop) and had it clear coated in Mercedes' famous ceramic clear coat. The paint was the largest step and I used a number of different colors to achieve the patina look.
Now, the lighting system!
Step 1Junk Fun MUHAHAHA!
Junk Fun MUHAHAHA!
I knew I had a general Idea of what I wanted it to look like, so I began collecting parts and pieces. Everything on the bike was stuff I found lying around the garage, with the exception of "D" Batteries, honestly what uses "D" batteries these days anyways? How many kids are still reenacting the classic boombox above the head to win the love of your heart thing? Are boomboxes back in style again? Is it sad I am old enough to remember when boomboxes were in style?
God, what a rabbit trail. Oh well, "D" batteries, I had to buy them...
Here is what I used but I find it best to leave some of your imagination in tact.
1 Lantern, classic old ugly red style, with a handle, garage sale find I believe. I repainted the metal parts and to make my lamp sparkle forward more rather than out, (God knows I need to have lots of light on my crotch while biking...), I took awesome gold spray paint, masked off most of the glass, etched, primed and shot the inside of the glass. This didn't turn out as well as I had hoped, but meh. Overall the effect is awesome.
4 "D" batteries. There they are again... Slightly used as once I had them, I had to break out the old boombox and Grier jammed it on his shoulder while I used some discarded cardboard to lay down phat dance skills and breakdance like a mad fool.
Speaker Wire! I love this stuff... I use it to hang things up, connect electronics, erotically asphyxiate myself, and of course wire up A/V equipment!
2 POS flashlights, the cheap kind, I tried to incorporate LED's but I am lazy, what else can I say?
Some spare copper sheeting...
1 LED toggle switch, easily found in the car electronics section of Wal-Mart, I had a few lying around and chose green, the red ones bother me. They make me think whatever I put the switch on is doomed to blow up at any moment.
Zip ties and copper wire. Okay so the zip ties weren't exactly in keeping with the steampunk theme, but give me a break, I wanted to be able to change out the batteries.
Wire cutters! Self explanatory, if you can't figure this one out please stop reading as the following steps of simple electronics will confuse the hell out of you!
35 comments
Jan 9, 2011. 8:58 PMlunius says:
"erotically asphyxiate myself" I see what you did there with all that extra speaker wire laying around xD
Nov 20, 2010. 5:33 AMMalk_MannĂ¯ says:
I've looked for projects like this for some time ... congratulations, it was beautiful, and is useful ^ ^ I will like so I can.
Jul 3, 2010. 8:23 PMjakdedert says:
Re: Age of the bike. Here's a site with a link to Schwinn serial numbers, along with their location on the bike (thinking they're on the bottom of the Bottom Bracket, but you can find that at the same site). http://www.re-cycle.com/History/Schwinn/SwnB_Serial.aspx
Jul 31, 2009. 1:27 PMDdraigGoch says:
Brilliant, in all the best senses! I'm almost inspired to start cycling again, it's that good. Thank you.
Mar 29, 2009. 12:27 PMSureShot says:
Good job, looks great. I really dig this whole steampunk thing.
Nov 20, 2008. 3:37 PMdowns says:
I don't get it. wouldn't lamp oil and a reflector be more steam punky?
Nov 22, 2008. 7:42 PMdowns says:
perform within the means of your equipment. Nothing like a good 3rd degree burn to keep you from showing off (you realize your friends talk about you behind your back when you pull those stunts, don't you? see below for punk / crash-burn correlation. I assume you've inspected an oil lamp. they are quite easy to fill whether or not they are permanently attached via the cap located on the reservoir. also, nothing more steam punk than bailing wire. (yes they still sell it, even at home depot.) finally you all do realize that a dynamo instead of a battery would have fully qualified this project as steam punk, not just "steam punk style", right?
Nov 26, 2008. 9:41 PMdowns says:
Sounds like a design flaw. Function before fashion I say. My light consists of two 15 watt 12v fog lights from autozone a toggle switch and a 20amphour 12volt gel cell battery. Not cute or stylish by any means but it got the drunken bums off the dark river trail bike path I used to commute to work; they figured I was a car which was the effect I wanted.
Here's a instructable from someone with no fear of fire. He too went for function before fashion:
http://www.instructables.com/id/Bicycle_Lantern/
Jan 26, 2009. 12:16 AMslithytove2 says:
I may be wrong, but I believe the whole intent of steampunk is kinda the other way around.. Fashion before function?
Nov 20, 2008. 4:20 PMPhantom5582 says:
It would be, but it would also be unsafe. If he crashed with an oil lamp, he can catch on fire.
Nov 22, 2008. 7:24 PMdowns says:
tell me, what's not punk about crashing and burning ? it's a sell out to modern tech.
Nov 20, 2008. 2:54 AMCalorie says:
Keep up the practice. I think the lantern idea has a lot of potential. There's an instructable on how to paint a bike that is excellent. You might get some good ideas on how to make your ride look sharper. It's an old bike, and a bit of mineral spirits will do wonders to remove any paint and allow you to try something new. Good Luck!
Nov 24, 2008. 5:06 AMmi5tergone says:
Fantastic job! I've been looking online for ideas for my own steampunk bicycle. I'm glad I ran across your instructable.
Nov 22, 2008. 9:57 PMstatic says:
A carbide lantern bones, would be more steampunkish, IMO.
Nov 21, 2008. 5:37 PMrandomray says:
Great bike .I really like the steampunk theme . Did you mean rabbit hole when you were talking about the boomboxes ? I also remember the bigger the boombox the better it was .Now the smaller the electronic equipment the cooler it is .
Nov 20, 2008. 3:28 PMgmoon says:
Great paint job!
Nov 20, 2008. 7:49 PMPhoghat says:
What color did you use to paint the bike?
Nov 20, 2008. 1:23 PMrdholtz says:
Terrific first Instructable, and a terrific read even for those who don't build a lighting system. Parenthetical expressions are fine (there's no such thing as too many); even semicolons are cool -- and so are hyphens. I love ellipses, too . . . Write some more stuff -- you're very good. Makes me want to come play in your shop with you and help you not finish some more projects.
Nov 19, 2008. 6:48 PMredplanet says:
Beautiful work. I'd very much like to see close-up shots of the bodywork and lantern, please. And you are fucking hilarious. I look forward to more instructables from you.
Nov 19, 2008. 5:27 PMHeWantsRevenge says:
hahaha...way cool...though maybe u could hide some highpowered leds in the front
Nov 19, 2008. 4:13 PMKentsOkay says:
Awesome! Love the styling.
Nov 20, 2008. 5:06 AMPKM says:
Well, you seem to have got the "make your writing entertaining for others to read" bit fairly well. I use too many ellipses as well, and hyphens when I really ought to use semicolons. Semicolons just look too formal, y'know? Anyway, enough of that- I'd love to build one of these if it wasn't going to be instantly stolen by scallies and used to set someone's car on fire. Great first Instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:freek723
I like DIY... a lot. I costume and build my own bikes and motorized objects. I think free energy is out there, we just haven't figured it out yet. I have bought plans for flying machines on ebay. I ho...
more »
