Bicycle North Indicator
 by amandaghassaei
Featured
Magnetoception is the ability of some animals to detect magnetic fields as a means of orienting themselves.  Although humans do not seem to posses the same biological mechanisms that allow other animals to sense magnetic fields, there are still many ways that we can improve our sense of spatial orientation.
This project is an attachment to your bicycle that beeps to let you know that you are moving in the direction of magnetic north.  It uses a parallax digital compass module, an Arduino, and a piezo buzzer to give you directional feedback as you bike.  The basic idea here is that by providing a constant source of stimuli in a certain direction, you might find yourself becoming more aware of other visual or sensory cues in your commute that indicate your orientation: geographical landmarks, air currents, inclines, or the position of the sun, moon, and stars.
(1x) Parallax 3-Axis Compass Module Radioshack 276-123
(1x) 85dB Piezo Buzzer Radioshack 273-060
(1x) Arduino Uno REV 3 Radioshack 276-128
(1x) 9V Alkaline Battery Radioshack #23-866
(1x) Heavy-Duty 9V Snap Connectors Radioshack #270-324
(1x) PC Board with Copper Radioshack #276-147
(1x) SPST PC-Mountable Submini Toggle Switch Radioshack #275-645
(2x) Male Header Pins Jameco 103393
(1x) Female Pin Sockets Jameco 308567
(1x) 9-Volt Battery Holder Radioshack 270-326
Additional Materials:
Heat Shrink Radioshack #278-1611
22 Gauge Wire Radioshack #278-1224
Solder Radioshack #64-013
zip ties
Drill
Screwdriver
4-40 x 1" nuts and bolts
Step 1: Schematic
The schematic above shows how simple this project is.  A 9V battery and switch are connected in series to the Vin and ground pins of the Arduino- this is the power supply for the project.  The Arduino supplies power to two pins of the compass module (see note in the image above) and analog pins A4 and A5 are used to receive data from the compass module.  the piezo buzzer is controlled by Arduino digital pin 7.
FriendOfHumanity says: Sep 19, 2012. 10:39 AM
Fabulous!
Lindie says: Sep 18, 2012. 1:02 PM
Very nice!
londobali says: Sep 18, 2012. 5:46 AM
Where the hey' do you get your ideas from?
i'd like to get me some too.. :)
Thanks for sharing!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
