Don't want to fork out a couple of hundred bucks for a bicycle stand? This easy to make stand will not mar wall, ceilings or floors. You can probably have up to four bikes on it, if you're creative. The photo below shows one way to mount a bike on the rack.
Step 1Parts list
You'll need a 4x4 for the base, some scraps for the pad block and legs, a piece of all thread (I recommend 1/2"), two nuts and a washer and four wood screws. I also recommend that you use wood that's as dry as possible or cedar for the base, as wet wood can split when drying. I had used pressure treated wood for a couple but have replaced them due to concern for chemicals used as preservatives. If you wanted to use pressure treated wood for a garage setup, that may be okay, just be careful to clean up the sawdust and wear a mask when doing the work. The schematic shows the general principle of how to put together the business end, the "pressing mechanism".
By force fit, drill a hole that is slightly smaller than the diameter of the all-thread. Then just pound it in to the support 4x4. When you tighten it, the axial compression will hold it in but if you drill a hole too large, you may end up with some play in it.
So, after searching instructables.com for a good storage/work stand for my bicycles, I decided to make a hybrid of this one and two others (see links). I even added some extras to it to make it super useful (like some old carpet wrapped around the bottom as a scratch post for our cat and some better lighting to help in toeing-in brake pads). You'll notice in the photos that I added a coupler (I think that's what it's called) to the clamping mechanism. This coupler allows me to spin the clamp and angle the bike at any direction I need while working on it. The extra prong-thing on the clamp adds the extra strength I lose I by using a PVC clamp. All in all, the materials were super cheap, maybe $35 total, I don't remember. Even the vertical bike hook was only like $7 at Lowe's. It works great for storage and maintenance.
