3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bicycle Stand
Bicycle Stand
  • Hanging bike
Don't want to fork out a couple of hundred bucks for a bicycle stand? This easy to make stand will not mar wall, ceilings or floors. You can probably have up to four bikes on it, if you're creative. The photo below shows one way to mount a bike on the rack.
Step 1Parts list
Parts list
You'll need a 4x4 for the base, some scraps for the pad block and legs, a piece of all thread (I recommend 1/2"), two nuts and a washer and four wood screws. I also recommend that you use wood that's as dry as possible or cedar for the base, as wet wood can split when drying. I had used pressure treated wood for a couple but have replaced them due to concern for chemicals used as preservatives. If you wanted to use pressure treated wood for a garage setup, that may be okay, just be careful to clean up the sawdust and wear a mask when doing the work. The schematic shows the general principle of how to put together the business end, the "pressing mechanism".
16 comments
Sep 18, 2010. 9:38 PMstruckbyanarrow says:
cool track bike never seen brakes mounted like that on bullhorns, cool
Sep 19, 2010. 4:50 AMciaran.mooney says:
I may be a bit dim here. How do you "force fit" the all thread? I just can't get my head around how to do it.
Dec 10, 2009. 10:01 PMwrenchead says:
Its probably a good idea to aim for a joist or some sort of structure.  If you miss and you're cranking on it, you could crack the drywall.
Mar 4, 2009. 5:35 PMbroscro says:
http://www.instructables.com/id/PVC-Bench-top-Bike-Repair-Stand/http://www.instructables.com/id/DIY-Home-Bicycle-Repair-Stand/
So, after searching instructables.com for a good storage/work stand for my bicycles, I decided to make a hybrid of this one and two others (see links). I even added some extras to it to make it super useful (like some old carpet wrapped around the bottom as a scratch post for our cat and some better lighting to help in toeing-in brake pads). You'll notice in the photos that I added a coupler (I think that's what it's called) to the clamping mechanism. This coupler allows me to spin the clamp and angle the bike at any direction I need while working on it. The extra prong-thing on the clamp adds the extra strength I lose I by using a PVC clamp. All in all, the materials were super cheap, maybe $35 total, I don't remember. Even the vertical bike hook was only like $7 at Lowe's. It works great for storage and maintenance.
Jun 6, 2007. 3:01 PMn0ukf says:
Before you position and tighten the rack, be sure you're centered on a cieling joist, not between them. Sheetrock is not a strong material to be bracing against, many people have stepped through it by stepping between the joists in their attic (some seen on ABC's AFV).
Dec 20, 2006. 12:31 AMbasscadetz says:
this is a great idea. thanks.
Jul 31, 2006. 11:38 PMboss7696 says:
i like your plans. especially considering that the wood stand at my bike shop costs 160! i'm considering doing this in my apartment. i can buy a nice cedar (4x4) for around 10-15 bucks. i have 2 bikes and would need to mount them horizontally. it would seem that some arms would need to be made to cradle the top tube. do you have any suggestions for this? thanks again! doug from 100 degree austin texas
Jul 29, 2006. 7:32 PMwesternorbit says:
Do be sure to re-check the tightness after a little while. I bought a similar ‘jack’ style floor to wall stand and had it almost fed a chainring to my girlfriend. It seems the weight of the two bikes had caused it to compress the carpet a tad, allowing the top plate to slip away from the wall/ceiling. I made a few improvements after all that excitement. I added some no-slip drawer liner to the top piece. This also lessened the marking on the ceiling. I also placed the base on a piece of plywood. This made the carpet less of an issue. I also checked the tightness of the whole setup every afternoon. Props for the homebrew rack!
Jul 13, 2006. 10:13 AMKoolKat says:
Sweet! Great idea.
Jul 8, 2006. 1:08 PMBranden says:
I've been trying to figure out something to do for the three bikes I have in my apartment. I think I'm going to give this a try. One question... You really don't have any issues with marks left behind after removing the stand?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:cavit8
