loading
Picture of Bicycle Top Tube Protector
I made this a couple of years ago, well before I knew about Instructables. I think it's a perfect topic: making something extremely useful from recycled parts / pieces. This is the kind of thing I've seen on BMX bikes.
Have you ever got cable pinch on your mountain bike, from where it sits in the bike rack on your car? This top tube protector will put an end to that!
Just so we're on the same page, I've added the anatomy of a bike in the picture.
Step 1: Ingredients
Picture of Ingredients
- an 18 inch long swatch of fabric that you won't mind seeing on your bike; this is the outer fabric.
- An 18 inch long matching piece of cordura nylon, or other durable fabric. This is the inner fabric, and should be able to take a lot of wear.
- Fabric widths may differ from bike to bike, due to length and circumfrence of the top tube.
- 1 inch Velcro hook and pile; as much Velcro length as fabric length.
- A piece of closed cell foam, like the stuff camping sleeping pads are made out of. I used a slice of my RidgeRest foam mattress.
- Measuring tape
- Scissors
- A sewing machine, although it can be hand stitched.
Step 2: Ingredients: Inner Fabric and Velcro
Picture of Ingredients: Inner Fabric and Velcro
Black cordura inner fabric.
Step 3: Ingredients: Closed Cell Foam
Picture of Ingredients: Closed Cell Foam
This piece of foam will fit into the sheath made out of the inner / outer fabric.
Step 4: Ingredients: tools
Picture of Ingredients: tools
A handy sewer with a sewing machine, scissors and the all important measuring device.
Step 5: Measure Thrice Cut Once
Picture of Measure Thrice Cut Once
If you're me, you go like hell, excited and willy nilly.
Lucky for me that the missus got a hold of this, measured properly and has the sewing skills.
Cut your fabrics and foam.
Step 6: Make a Model
Picture of Make a Model
As with a lot of projects, I (the missus) pinned the whole shebang together first, as a big envelope, and made sure the foam would fit.
Step 7: Vecro-ize
Picture of Vecro-ize
I'm sure that after a fair amount of adjusting and pinning, my missus sewed the Velcro on in such a way that it is concealed from view.
Although I'm lucky enough to have a sewing missus, this project can be done by hand, if you've the patience. A quick and dirty solutuion is to just zap-strap some foam to your top tube.
Step 8: Velcro picture
Picture of Velcro picture
Here's a good view of the finished product, not mounted, detailing the Velcro. Boy, am I lucky to have married my missus.
Step 9: Mounted view 1
Picture of Mounted view 1
Here it is, mounted on your UAB (Urban Assault Bike). This fits over the cable housings, doesn't interfere with gearing or braking, and is better loose, not too tight. So far, no more cable bite, and it's easily removable.
Step 10: Armoured Top Tube
Picture of Armoured Top Tube
Another view of the mounted protector. As a final flash of brilliance, envision 2 strategically sewn Velcro loops on the top of the protector, to hold your bike pump, as you pedal your butt around town.
Cool, eh?
Katie57574 years ago
Make ensure you instal the pump on the underside of the protector.. Assuming it is for the protection of body parts..also. padding on the vertical frame might be in order in case the pubic bone connects in a forward motion.
Do you learn how to fall from your bike, as with a motor cycle?
kretzlord7 years ago
well, someone should comment. Good instructable, and congrats on having a missus that sews. My only suggestion would be that, rather than use closed cell camping pad foam, you could get pipe insulation from a hardware store that has the same inner diameter as your top tube. It already has a slit cut in the side, so you cut it to length, make it look pretty, and protect the holiest of holies. and since it holds it shape, the velcro *might* not be required to keep it on. Again, great instructable, and happy riding!
Pipe Insulation. No Doubt. Easy, Cheap, Plentiful. Use on any part of the frame
Dan Schmidt6 years ago
lol, I rocked a top tube protector on my bmx bike when I was 12. after seeing your instructions, i can relive my childhood!
Evil Bike6 years ago
I see you have a Norco, what type is it? Great Idea!
error4046 years ago
I got an old bicycle inner tube and wound it about the top tube ensuring that there was about a 59% overlap and secured each end with a couple of BIG cable ties. Works brilliantly and doesn't hold water.
Pwag6 years ago
I gotta say I'm a bit disappointed I was hoping for a tube top made from a bicycle.
